I replaced battery in my audi 80 2.0 tdi but have lost the remote and alarm wont stop going off .
Depress lock or unlock button. Manually lock and unlock driver's door within 30 seconds. System should now lock or unlock vehicle. If not, carry out programming procedure.
Programming
When
Key added or replaced. System malfunction: Alarm LED in rear fog lamp switch illuminates for 30 seconds when vehicle is locked.
How
NOTE: A maximum of 4 keys can be programmed (one at a time).
As memory positions of existing keys are unlikely to be known: Obtain and reprogram all keys.
NOTE: Existing key memory positions will be overwritten.
Switch ignition ON. Use key not fitted with remote control. Manually lock vehicle using key. Using first key, press unlock button once (programs memory position 1). Alarm horn sounds once to indicate signal received. Wait 6 seconds. Press unlock button once to confirm programming. Vehicle unlocks. Programming mode deactivated. Switch ignition OFF. To program remaining keys into memory positions 2, 3 and 4. Carry out the complete procedure below for each key: Switch ignition ON. Use key not fitted with remote control. Manually lock vehicle using key. Press unlock button at 1 second intervals, as follows: Twice for memory position 2 (second key). Three times for memory position 3 (third key). Four times for memory position 4 (fourth key). Alarm horn sounds once every time unlock button is pressed, to indicate signal received. Wait 6 seconds. Press unlock button once to confirm programming. Vehicle unlocks. Programming mode deactivated. Switch ignition OFF.
NOTE: Ignition MUST be switched OFF between each key programming procedure
