Last week while attempting to start the machine, three error codes appeared as I was attempting to get through the problem. I scoped it out myself on line, purchased the machine control board and replaced it. FL still. Replaced the OPR switch. FL still reads out. I'm stuck.
We are not technicians, we do not have technical training, or technicians here in customer service. We can
offer troubleshooting. Unfortunately, we do not have the provisions to assist you with detailed technical advice, provide
repair manuals, tell you how to take it apart, or advise on which parts need to be changed to repair the unit. We do not offer
repair assistance in customer service. If you are unable to resolve an issue on your own, we can only recommend service, as
we do not have any technical line that customers can use.
Most companies do not offer technical assistance due to liability issues.
SOURCE: my whirpol calypso washer don't running, appear fl and ce
"FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display
If there is any breakdown in communication between the machine controller and the motor controller, "CE" flashes and the unit beeps once.
Some common causes of "CE" errors include:
• Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
• Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
• Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a "CE" error will occur.
• Drive motor thermal protector has opened.
• Motor controller is not powered or fuse has opened. Replace motor controller.
Press STOP/CANCEL to clear the display.
SOURCE: I have a CE error on the Calypso washer. I remove
First off is it under waranty and second you will need to find out what Ce stands for.Ask a repair shop and they might let you know what the code stands for.
No need changing something that don't need to be.
If it's not under waranty I would say yes you could replace it.The wires are usually all different and no way to get them hooked up wrong.(Note Just Make Sure It's Unlugged.)
SOURCE: Whirlpool Calypso error code reads FL...
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Should you continue to have appliance issues or need parts or service advice, please don’t hesitate to contact us. We are at your service from 7 AM until 9 PM CST Mon – Sat!
Thanks, Ella :>)
SOURCE: FL code washer not draining
“FL” (Over Fill) flashes
The washer will beep every 10 seconds with no time-out. The
pump will cycle one half minute on, one half minute off, until
the overfill switch is reset or power is discontinued to the unit.
Press STOP/CANCEL to clear the display. Shut off the water
faucets to the inlet hoses if water continues to flow.
Here is the complete manual.
