Paper jam in xerox copier 5328
My xerox copier 5328 indicates a paper jam. Meanwhile there is no paper in the copier. how could this be cleared from memory
  • McLlinus Djata Atieku Dec 31, 2008
    Thanks so much. I've traveled away from the xerox machine now. I'll get back to you when i return.
    Regards
    Djata
Specify the area of paper jam or the code on display that cud help isolate the problem quicker, it cud be a C or E code. Try to clear it with code 20 subcode 03, but state code on display
Posted on Nov 07, 2008
6ya staff
SOURCE:
Xerox Copier 5328 Paper jams where the baffle located. Goes through but does not come out. is
Sounds like a fuser problem. Also, because this is a very old model, constant heat over time can warp plastic paper path guides which will cause strange jamming. These issues hare sometimes hare to pinpoint. Why not get a new copier?
Feb 13, 2014 | Office Equipment & Supplies
I have a Fuji Xerox 525a colour laser printer which is giving a phantom paper jam message (error message indicates paper jam in cover E, but it is clear) What can I do to clear this message as it...
I beleive there are only two paper sensors for that machine.
1- in the tray there is a paper empty sensor which hangs down,
make sure you take out the tray and look for any pieces of paper stuck.
2- open right door and look as if your looking inside to where the paper is supposed to end up. The sensor is in that black unit, is there any paper there, can you see a black lever, if you pull on it gently and let go does it snap back in place?
Jun 21, 2008 | Fuji Office Equipment & Supplies
Xerox Workcentre 4150. Paper keeps jamming in print engine area. We clear the jam and it jams again.
If your Xerox WC 4150 is displaying "Clear the Jam in the Print Engine" or constantly jams as paper exits the machine you should check and possibly replace the fuser actuator (part# 120N00534) This is the most likely cause, if however this does not fix the printer the next step may be to replace the sensor or fuser.
Here is a video that shows you how to check and replace the actuator. ItemInc.com has this part in stock and ships same day. Good luck, and thanks for using FixYa!
Jun 23, 2011 | Xerox WorkCentre 4150 Black and White...
We had a paper jam in the print engine area. Once the paper path has been cleared we are still receiving clear misfed paper in print engine. I have fed paper through the path and cannot find any paper jam.
If your Xerox WC 4150 is displaying "Clear the Jam in the Print Area" you should check and possibly replace the fuser exit actuator (part# 120N00534). Iteminc.com has this part in stock and ships same day. Here is a video the shows you how to check and replace the fuser exit actuator. Good luck, and thanks for using FixYa!
Jun 17, 2011 | Xerox WorkCentre 4150 Black and White...
08,045.43:5458 power outage happened, when power
This error indicates that the paper path motor stalled. Clear the paper jam, power off the printer for 30 seconds and then turn it back on.
Here's how to clear a paper jam from Xerox website, depending on the location of the paper jam: http://www.support.xerox.com/support/phaser-8560mfp/support/enus.html?operatingSystem=win7x64&fileLanguage=en
Feb 19, 2011 | Xerox Phaser 8560MFP Laser Printer
XEROX PHASER 6180 SAYS PAPER JAM, I CLEARED PAPER JAM, PUT IN NEW CARTRIDGE, AND IT STILL SAYS PAPER JAM
Check the fuser for paper stuck in it.
Check that the 'paper out' sensor arm (in the fuser) is not broken. If it IS broken, you'll need a new fuser.
Mar 16, 2010 | Xerox Phaser 6180N Laser Printer
What does code J1 mean on a xerox work center pro?
J1 mean any paper jam in paper feed area or sensor displace.lower cassate or multi pass tray.clear jam paper then solve your problem.
Dec 23, 2009 | Xerox WorkCentre M-24 Color Copier
Rank xerox 5328 U9
if its a u9-1 code it is the lamp that is faulty. Sometimes it can be the connections either end of the lamp but normally the lamp itself. It will probably cost as much to fix as it would to get a new one to be honest
Nov 03, 2008 | Xerox 5830 Copier
XEROX 5328 COPER
Total weight is about 200 pounds. But, that machine comes apart.
You can take off the thumb screws and disconnect one plug and lift off the document feeder.
The machine processor separates just above the tray 2/3 module, also the tray 2/3 module separates from the stand. So you can make is much easier to move by taking it apart. Nothing is bolted together, just sits one on top the other.
Jul 07, 2008 | Xerox WorkCentre M-24 Color Copier
Open Questions:
176 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
