eMachines E19T5W 19" Monitor Logo
Posted on Mar 01, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HD MONITOR E19T5W resolution settings
What is the correct resolution settings for this model?
Jeffrey McDaniel
Level 3:
  • Master 669 Answers
  • Posted on Mar 01, 2012
Jeffrey McDaniel
Master
Level 3:
Answers
669
Questions
0
Helped
200396
Points
1944
Native resolution is 1440 X 900
  • Jeffrey McDaniel Mar 01, 2012
    Native resolution: 1440 X 900
2 Related Answers
Anonymous
  • Posted on Aug 24, 2008
SOURCE: what is correct resolution for e17t4w
found correct setting on vista windows support, for emachines flat screen 17". the setting is 1280x720.
Anonymous
  • 670 Answers
  • Posted on Jun 14, 2011
SOURCE: my e-machines flat screen
Please check if the button is stucked or if you feel it click when you press on the menu button.
Is it a separate monitor or are you using an All in one computer?
If it's a separate monitor try to unplug it from the power source and then have the front lid opened to check if the Menu button has a problem.
is there an option to reset to defaults? if there is try pressing that button and see what happens.
Hope this helps!
Help to adjust full screen on the monitor
Hi, this depends on your operating system. Most likely your resolution settings are off, or a monitor setting is not correct. If you are in Windows, go to control panel -> appearance -> display settings -> resolution. Make sure you choose the highest resolution, for a 1080p monitor it should be "1920 x 1080".
If you are already on the highest resolution in the control panel settings, try to get into the settings of the monitor or resetting it, if you provide the model number, I can help you with this.
E19T5W monitor doesn't stay on once power button is depressed
Chances are the power supply in the monitor is going out.
Today, monitors are cheap and unless you have a 24' or better, it really doesn't pay. You may spent $100.00 and find one new for $135.00
Hope this helps
Fix resolution
Hi,i actualy bought an aoc 2243fw2k led monitor,i hav a nvidia geforce 220gt graphic card,even though i installed the latest drivers for both graphic card n the monitor,i stil cant experience high...
1920x1080 resolution is the starting point for HD video. If you have set your desktop resolution to that or anything avove then you should be running at HD resolutions. Maybe the image/video you are watching is not at a HD resolution, therefore it will appear distorted and streched (poor quality). To fully experience HD playback use video files and imaged that are at the 1920x1080 resolution and above.
I cant set my monitor resolusion 768 x 1366
In order for the computer to make certain resolutions available, your monitor has to "tell" the computer which resolutions it can support.
In order to make sure this happens, you can install the driver for your monitor. If you google the brand and model of the monitor, you should be able to find it.
Once the monitor drivers are installed, the computer will make those resolutions available for you to use.
Are you sure it is an HD monitor? Does your video card support HD output?
2answers
How do i set my x193w lcd monitor to hd?
install the CD that came with the monitor else right click on monitor screen in windows and adjust on properties menu
3helpful
2answers
My type pics etc looked squished horizontally
There is a fix have you tried auto configuring the monitor?
22'' LCD monitor aspect ratio is off.
Set resolution to the native 1680 x 1050. Then, using the buttons on the monitor, go into the monitor's menu. go down to "Image Setting", go to "HDMI Mode", then select "PC Mode". This should help everything fit on screen correctly.
2answers
Hello, i have a windows vista basic from walmart and i just purchased a proview model#pl926w series flat panel monitor from walmart and need to know how to obtain the 1440x900 resolution. the set up guide...
Yes,you obtain high resolutions.
Do the following steps.
1. Open Display Settings by clicking the Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Display Settings.
2. Under Resolution, move the slider to the resolution you want, and then click Apply.
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
