Microwave "DOOR" in display.
Most likely the switch that senses whether or not the door is closed is either out of adjustment, meaning when the door closes it doesn't physically make the switch contacts close, or the switch is defective. If you can physically find the switch you can "trick" it by holding it closed with a piece of tape. If that works then the switch is simply out of adjustment. If that doesn't work then you can short together the two wires going to the switch which simulates the closed internal contacts of the switch. If that works your switch has failed. If neither works then you may have a broken switch wire or solder joint where the switch inputs it's signal to a circuit board. If it is a bad circuit board you may spend the same amout of money replacing the board as you would buying a new microwave. Please be careful with theses test procedures and remember dealing with electricity can be a shocking experience! Good luck.
THE DOOR HOOKS ON MY MICROWAVE HAVE NO TENSION ITS MODEL R-120DW AND IT WON'T TURN ON BECAUSE THE DOOR LATCHES WONT STAY ENGAGED ONTO THE DOOR
AFTER SEPARATING THE DOOR PANELS HOW IS THE SPRING RE-ATTACHED AND WHAT IS THE REPALCEMENT PART NUMBER ?
Same problem with a bosch microwave...
emerson 110 watt microwave
door will not close
the microwave is only a year old and if its not much i would like to fix it, It was working fine until this happend
