Error 03130031-2618
Hardware error. 03130031-2618
Turn off printer, wait, then turn on again.
03130031-2618 VH voltage error
Check the power supply unit.
Dear fix ya member,
The problem is in the mainboard, you must check the printhead first, before change the mainboard. Why it can be happened?
The Print head have a short circuit on the heater voltage, and the supplay voltage came from the main board. It is totaly problem from the mainboard not at the carriage unit, or the power supplay.
please contact me if you wat to fix your plotter mainboard. My email is [email protected].
SOURCE: My canon IPF8000 printer has
In my knowledge the error indicates the voltage on the print head is abnormal. It is an hardware related issue.
Possible cases can the print head is faulty or the relays to the PCB may be faulty or the PCB itself.
We have to perform continuity checks between the relays and between relays and PCB. then we can confirm if the relay is faulty or the cables between them . If not print head would have failed and needs to be replaced.
SOURCE: hardware error
Follow these steps :
Cause: The Voltage of the print head is abnormal.
Problems can be with:
-Printhead
-head relay PCB
-Carriage relay PCB
-Main controller PCB
Steps to be followed:
1. Replace the printhead.
2. Cable continuity check.
if continuity of the cable between the head relay PCB and the carriage relay PCB is abnormal, replace the cable.
3. Replace the head relay PCB.
4. Cable continuity check.
if continuity of the cable between the carriage relay PCB iand the main controller PCB is abnormal, replace the cable.
5.Replace the carriage relay PCB.
6.Replace the main controller PCB.
SOURCE: I have a cannon IPF700
you must test the cabel.which go form your haeds to your mainboard. had the same probem cabel was broken at the back side. cut it cleaned it and tested all ok.
Dear fix ya member,
I have this error
I change the printhead
The error is there
What can I do ?
