Got the scooter for xmas last year -- has been used approximately 5 times. SHows battery is fully charged. Will not go. Need help.
hello,,i'm not overly familiar with these but,,here goes,,,,if it is reading fully charged,,but it will not go,,,,if you have an electrical tester,,,plug the red probe into the red wire connector on the battery,,,,and the black one to the black connector on battery,,,,,just to be sure charge gauge is reading correctly,,,,,,if it is indeed fully charged,,,,now go to where you engage the power,,,,whether it be a pedal,,or a trigger on the handle bar,,,,,you will have to check all connections to be sure one has not come off,,,,or got to lose to make a connection,,,,if all looks ok there,,,,check the wires that go to the motor ,,, from the battery,,,,make sure all is secure,,,,, if it has gotten wet,,,check for any corrosion on all your electricals,,,,,,and clean ,,,,,when your doing all this,,,,,also check for a broken wire,,,,,or stripped wire,,,, hopefully these steps will put you in the right direction and back to riding,,,,, JOEL
