Has a hi-p code
SOURCE: Model Robinair 34700 Series 21699
Please do the following 1# Check your machine ISV tank liquid line quick connector.it's seems to be very tight,open little & try to charging.2# Rebuild charging solenoid.
SOURCE: I have a Robinair 34700, during vacuuming and
Don't worry this is normal.Because while machine is running for vacuum or recycle mode,automatic air purge device will active for some time & it will purge air from ISV.
SOURCE: I have a Robinair 34700 A/C machine that the freon
YOU NEED TO REPLACE OIL DRAIN SOLENOID OR OIL DRAIN SWITCH
