Question about Panasonic KX-T7730 Corded Phone
Changing the names for extensions
At work we have Panasonic KX-T7730 and i just wanted to know how to change the name it displays for an extension???
  • 6 more comments
  • Integrated08 Oct 30, 2008
    sorry i hope i dont sond stupid but can i get those complete instuctions?
  • Integrated08 Oct 31, 2008
    OK so ive done exactly what you said the only problem i have is that when i try spelling the name for example LIAM. instead of saying LIAM it stores as the numbers 55544486???
    i have no idea where that is id have to ask my boss who is not in. :(
  • Integrated08 Nov 04, 2008
    sorry im soo confused! i dont know enough about phone systems :) do we know how to get it from storing numbers to letters?
    i had followed your instrustions and i changed the pervious name to the numbers... can that still mean im not going into programing.
    ok how do i check the system my boss is again not here :) but if you tell me where i could find it or what it may look like ill try find out
    Thank you again for being so patient
    DONE WOHOOOOOOOOOOOOOOOOOOOOO i just dialled the letter then AUTO ANS/MUTE like you said it changed the number to the letter :)
    Thank you for all your help
  • kapas20 Nov 06, 2008
    I want to add name at the extensions of a Panasonic KX-T7730
  • hale barns Nov 11, 2008
    I have a KX-T7730 phone at work, I am on the switch, the main phone, I have programmed the six lines with fixed dialed numbers, I do not know how to delete them and I can not get a line out. Please help.
  • Panasonic Master
  • 2,460 Answers
Name changes are done from the System Administrators phone. In the TA-series, it's system program 604. In a TAW it's 004. I can give you complete instructions, but you have to get to that screen first.
If you get there and want to play, the SP Phone FWD CONF MUTE and keypad press up to 7 times enter the Alphabet names (space is under 1). Nothing writes until you press STORE.
Carl
Posted on Oct 30, 2008
  • 3 more comments
  • Carl Navarro
    Carl Navarro Oct 30, 2008
    Find the phone for the system administrator. It's usually 101. From that phone, press PROGRAM and dial *#1234 or **1234. If the display says SYS-PGM NO?, dial 604 and when it says Extension Name press SP PHONE 2 times. It will now display #01: and a name. Keep pressing SP PHONE until the name you want to change appears.
    So here you're on your own, but if you want to spell Carl :-) Then press 2 (3 times) FWD 2 (4 times) 7 (7 times) and 5 (6 times) then STORE
    SP PHONE steps to the next jack PROGRAM ends programming.
    If you have a different system, the programming is similar in 004.
    Carl
  • Carl Navarro
    Carl Navarro Oct 31, 2008
    Please wander to the back room and check out your phone system cabinet. The one that won't behave would maybe be a 123211D cabinet. It's unlikely as the programming codes are 2 digit.
    If you find the model number, I'll get you the proper directions.
  • Carl Navarro
    To be fair, a Panasonic 7730 will plug into a cabinet made 20 years ago and still work completely.
    They have made about 18 different systems in that time. BTW the good thing is your 20 year old Panasonic phone will work in a new cabinet :-)
    In those years, we have gone from a cabinet where you had to go to the main box and flip a switch to program to one where you can press PROGRAM on any phone and program the system. We went from simple 1/0 area codes to 6 digit screening.
    Each of these systems have retained most of the programming in the same location...time is always 00 or 000, Speed dial is always 01 or 001, but some of the features differ between how it's entered and displayed, and some, like set names differ in where they're located. In some it's 004, 604, 64 and so forth.
    If you never press ENTER or STORE, you can examine what's in the program and even start to change it. It doesn't write until you tell it. Navigation within the program is done with the HOLD (top level) SP PHONE, CONF FWD (for back and forward) and AUTO ANS to select different features.
    As a dealer, I have electronic and paper copies of every system that Panasonic makes, and access to internet copies of most of the recent ones. So if it seems frustrating that your question isn't instantly solved, realize that the phone is just the instrument and it knows nothing. It just responds to the program in the box.
    Carl
  • Carl Navarro
    Carl Navarro Nov 04, 2008
    My guess is you're not going into programming. I believe the last post from me asked you what sytsem you have and you were going to ask your boss.....
  • Carl Navarro
    If it worked before to get to numbers and every time you press a button, even the same on you get a character on the screen, then try pressing the AUTO ANS/MUTE button after each keypress.
SOURCE:
Panasonic kx-t7730
What are you using to program.
PT Programming or you are using a PC Tool?
Did you save after setting names?
Jan 02, 2014 | Panasonic BTS Panasonic KX-T7730 White...
I have panasonic kx-t7730. How to set the intercom name and number?
Changing the name and extension number can be done through system admin programming from a phone extension allowed by the class of service assigned to that extension by the phone system installer. Typically the attendant phone is allowed this ability. From the programming phone press **1234(1234 is the default password) to access programming. Once in programming dial 003 for extension numbering then press . Enter the current extension number of the phone you want to change followed by the new extension number then press . Lift the handset to end programming. Access programming again by pressing **1234. Dial 004 for extension name programming then press . Enter the new extension number you programmed then enter the name for the extension. Press then lift handset to end programming.
It is possible that your phone has not been assigned an extension number, in that case system installer programming would need to be accessed to assign the port an extension number. The port number the phone is connected to would have to be determined. This could require tracking the wiring back to where it is connected into the phone system. If this is the case I advise calling a qualified service technician.
Dec 08, 2010 | Panasonic KX-T7730 Corded Phone
Changing the name of user on panasonic phone
Press program *# and your system password (default is 1234). Enter 604 then press SP-PHONE. Keep on pressing SP-PHONE until you get to the desired extension number. Change the name and press AUTO DIAL / STORE. Press program to leave programming mode and you are done.
Mar 09, 2010 | Panasonic KX-T7730 Corded Phone
Changing names for extensions on KX-T7667
How do I change the name on one extension please.
Sep 24, 2009 | Panasonic KX-T7730 Corded Phone
Names
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system. From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press PROGRAM * # followed by the system password ( default is 1234). Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ). Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered. Press PROGRAM to exit program mode and you are done.
PLEASE rate / vote this answer if it was helpful.
Thank you.
Jul 17, 2009 | Panasonic KX-T7730 Corded Phone
How do you program a Panasonic KX-T7730?
I assume that you want to program the extension names.
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system. From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the hook/cradle press PROGRAM * # followed by the system password ( default is 1234). Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ). Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered. Press PROGRAM to exit program mode and you are done.
Thank you.
May 18, 2009 | Panasonic KX-T7730 Corded Phone
The incorrect name being displayed when you use a preset number
The side buttons is programmed as extensions
To change the extension names follow these steps :
From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
1. Press PROGRAM * # followed by the system password ( default is 1234).
2. Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ).
3. Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change.
4. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered.
5. Press PROGRAM to exit program mode and you are done.
Jan 12, 2009 | Panasonic KX-T7730 Corded Phone
Lost panasonic KXT-7730 password
If you lost the password the only way to get into programming mode is to reset the telephone system to factory default. If you are not accustomed to all programming features this is not recomended because resetting will whipe out all programming including ringer settings, extension names, speeddials, routing and class of service. If you still want to reset let me know.
Dec 10, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic Adv Hybride System KX-T7730
Thank you.
Sep 18, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730 Corded - change display
On mine I press the asterix to toggle display options
Mar 31, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
583 people viewed this question
Top Panasonic Lands Phones Experts
Ekse
martin hogg
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
