Hi bought bush fdv200 hp pocket camcorder the other day. turns on ok but you need to put sd/sdhc card in to take photos and film etc....so i put sdhc card in from old camcorder...but screen shows "card error message". I have put the sd card into laptop and saved all pics films then emptied the sd card so know its not full. any ideas?
SOURCE: R 0:00 -- can't play back tape
try to clean the video head...i advise to use a blank tape and fastforward it until the time code counter display...you should on it the menu of the camera..
SOURCE: Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
I recently bought a DMC-TZ3 and have been researching memory cards. Several sites sell cards with the camera and list the card type. I would suggest buying one of these cards. Any cards larger than 2gb must be SDHC type SD cards. There appear to different types of SDHC cards, 1.0, 1.1 and 2.0. Check out Wikipedia.org for a description. 2.0 cards are not compatable for devices developed prior to 2.0 so that may be the reason for the camera problem. So far I haven't seen anything that states what type SDHC card the camera requires. I found a computer memory site that that sells memory that they say will work. There may be others.
http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/Panasonic/Panasonic_Lumix_DMC-TZ3
SOURCE: Ativa memory card
The card is probably formatted with a FAT16 filesystem. Try reformatting the card with a FAT32 filesystem.
SOURCE: transfer my minidv camcorder film onto DVD
You need to download the movie to a computer and store it in a video file. Then you should be able to use a software program to burn it to a DVD. I use a TIVO for watching and burning my videos. You don't need a computer. You save the video by recording it to the TIVO's hard drive then after it is on the drive you DUB it to an empty DVD-R disc.
SOURCE: Camcorder to computer
u need the dv cable out from the camera , to usb going in to the computer and more than likely the drivers that will probably be needed. Also you will need a certain software program that is compatible...usually comes with the driver.
