Hi everybody,this is ramakanta from India.My motherboard is AsRock P4i45GV R5.0.Presently neither I am getting any beeps after opening the RAM nor any display.Only CPU fan is moving.I am not getting POST screen too Is there any body who can tell me where must be the problem???
Obviously, it could be a transcient error or what we call the soft error. There could only be two culprits if you encountered this kind of problem. One is, it could be the power supply. If the power supply is faulty the electricity that flows within it (which is AC converted to DC)could have a lower or higher amount of electricity instead of a normal rate.
But if your PSU is working properly ( you could check it by swapping the PSU to another system unit ) then it could be the MOBO. According to standard IBM POST error codes, no beeping sound could be a faulty PSU or MOBO. It is more practical but to replace the MOBO, but still you could use the memory, videocard, HDD and other devices.
How to fixed your motherboard no display and no beep, 1st you must clean your memory using eraser and brush for painting if not display again try to clean your video card if have a video card using again the eraser and painting brush if not display again try to pull out the bass in the cdrom and floppy disk. if not display you must replace the memory and video card., if not display try to change your motherboard. The beep put speaker in the motherboard.. gudluck guys
Try reseating your cpu or make sure that your cpu is working :-/
I have the same problem and same motherboard as i u... i have 3 pcs all having problems in post... one i revive just by clearing the cmos but the other two stil a blink... only the cpu fan is running, i dont even get beeps on removing the memory and turning on the motherboard without the memory... i tried to get a working powersupply, graphic card and memory stil its a blink. i tried also removing the processor thinking it may be the causing the trouble but it works with other pc... so i conclude it is the board that causing problems... i guess its fried... before trying to buy for a new one, i suggest try to clear cmos and check it yourself by testing it with working parts... but i definitely conclude its motherboard is fried up... hope i have shared something could satisfy u. tc and may the force be with you...
Computer on.no display on my computer.
cpu fan are running starting time.after some seconds fan is not running
Well, I too had the same silent unit problem. The only thing that worked was the system fan, the hard drive and the DVD. I tried a different (working) CPU, and the original CPU worked fine on another MOBO. Tried a different (working) power supply, memory, graphics card, still nothing. I just cautiously popped out what seemed the be the BIOS chip (it read K7S41GX....), cleaned the pins 0n the chip and on the MOBO and carefully replaced the chip. The system booted fine after that.
Check Your CPU properly connected or not and also check RAM.
But There are 3 major region no display on monitor.
1. CPU Check.
2. RAM Check.
3. CMOS Battery Check and CMOS Jumper.
finally check VGA i.e. Video Card.
The problem is with your bios jumper and the reset when you on your computer long hold on reset button then it will automatically reset your PC to your normal way now your problem will solve just on your computer it will boot normally
Hi its me Tingsnet, i have the same problem too..I turn on my computer and ders no display in the monitor..I tried to clean da memory and videocard, nothings happen.. Wen i detached the memory and videocard in the mobo, and turn on again, ders nothing beeps or sound coming to the motherboad..what can i do to fix it?
im using AMD ATHLON (TM) 64 PROCESSOR 3200+
MOTHERBOARD IS ECS
Friend! Just replace a New CMOS Battery and start the computer!! Thats it!!! Try it!!!!
Hi i am diljeet singh my asrock motherboard no display give me solution
Check the display settings on ur monitor. is there is effect. if not then remove recent installed hardware. if not works then remove RAM card in re-insert it.
Hi.I have a same problem.but i can't solve it.
i have a albatron M.B and intel pentium 3.40 ghz cpu.
when i power my pc on, all fans turn on but cpu does not beep and post not show.
i pick up all hardware(VGA,Ram,Modem,....) and just cpu&Power connect to M.B.
therefor, i do it but cpu does not beep.
please help me,i need it.
Sheephead you should post a new question rather than piggy-back on this one. Also if I understand you correctly you?re saying your PC works with the old graphic card. Please post that info in your new posting. Mantu, while it could be a bad video card if you?re getting no POST beeping or video display I would be more inclined to suspect a power supply related issue or a short. Did you recently do something that lead to this problem?
First check the fan is rotating, then ram will cleaned,or change the slot after cleaning,
cmos also check, then check the short of mother board,
the mother board is removed from body,and cleaned, thats all...............
Hiiiiiiiiiiiiiiiiiiiiiiiiii
Just remove your ram and clean it..and it will ok..
Hello All if there is display prob.. then
I hope now you get the display. Its normal prob..this is only connection problem.
if not solve then assumable again you system (Remove all things then again assumable your system)
Regards :-
R. PANKAJ
I had the same problem with my P5N32-SLI Deluxe....tried everything, even replaced the PSU...replaced the MOBO and she fired right up
DONT TAKE TROUBLE...GET A NEW MOBO..I'm also getting one
It could be one of two things, in my opinion. Either you have a bad graphics card (in which case the BIOS should be giving you a beep error code), so you should try to test your graphics card in another machine. The other thing it could be is that the cooling fan isn't properly seated on the cpu or you have too much thermal compound that is sitting on the bridges of the cpu (the thermal compound should ONLY cover the CPU core).
Please change mother board!
I have an idea in that situation,,,,, try to change your power supply.... thanx
First, try another power supply if it is supplying enough power..sometimes damaged power supply can lighten your motherboard LED because it only consume small amount of voltage..
try another memory and video card..
if its still doesn't work try to remove the motherboard to the casing then touch the back of your cpu..if it is hot, open the heatsink then put some silicon heat transfer compound..
gudlucks..
Try replacing the motherboar.... i had 5 simillar problems...
I dnt know
If cpu fan stoped cause oh over heating u may check your termal paste...but if your cpu fan contiously rotate turn off and hardreset your bios jumper it the pin for 10 minutes and press the button to turn off and remove the jumper and press again the button to power on and its normally boot with display.... :)
Simple problem: first Check the DC voltage of your power supply. then if it is good, then remove your memory(RAM) try to to insert other PC if it is ok.. then you can now change motherboard.. thank you
Check for the jumper in your board its posible te jumper is disconnected or remove
No display
Initial troubleshootings:
1. Clean the RAM memory and try on other slot.
2. Check whether your mobo is not touching to metal body of cabinate, that can make short ckt on mobo and no display.
3. Check your power supply is enough to give display, try by removing power supply to HDD and FDD.
Yeah solution # 2 is the best ... all you are Madarchodss... and gandu also.. replace the choot slot.. and put lund properly.. and then you hear beep continiously..
I am rajesh. I have MSI 915GM mother board. Processor fan was moving but no beeps and no display. pl tell me sutaible reply for solving my problem.
I m using intel d865dvhz motherboard...i experieced no display and anoany beepy sound on cpu...how can i solve this
Im having the same problem only though my monitor wont even start up. The system starts no beeps though. Im using Asus M2N SLI Deleux with dual sli xfx 8600Gt Iv been hacking at this pc all day and dont know what is up.
Hi everybody, Im Katirongo from Kiribati.My motherboard P4S533.VM. The problem was when I turn on the power there was a Green Light on the motherboard, but when I boot up the computer there was post on screen.20 or 30 second and it automatically shutit down.
Set your board to jumper free mode if you have it.check voltage for video card.
How many memory sticks do you have in it if you only have one you need it in the 4th slot my done the same thing and i move it got it going
Had the same Problem: Take every thing out 1 at a time till all you have is the CHIP let in there. It does work.. Found it was my Chip in the end. If you ONLY have the CHIP in it should still POST.. Take out memory>hardive>DVD Drives,the LOT. Then gradualy put them back 1 at a time.. Good luck.. IT DOES WORK BELIVE ME.. Crazyseedy. uk.
Hi all! If you have similar problems check up condensers around of the CPU. It can be "pregnant"? Replace condensers on similar if you are friends of a soldering iron.
Hi, This is aploy of philippines. We had encountered same problem last time. The technician told us the problem was on the motherboard.
www.txtmate.com
SOURCE: No beep,No Display on my monitor,only CPU heatsink fan is moving
have you thought about changing the battery on the motherboard, also checking that the fan on the cpu is seated properly with enough heatsink paste as both these issues will stop the pc from booting
my motherboard has problem with no beep and no display
No beep,No Display on my monitor,only CPU heatsink fan is moving problem,
I'm using a DFI LanParty UT RDX200 CF-DR motherboard. I'm experiencing the same problems as addressed by Mantu. I don't have any beep codes at power on, nor do I have any display or display signal on my monitor. The cpu fan and the floating chipset fan do engage at power on, however, that's the best it gets. I've ruled out a bad video card and ensured there is not too much thermal grease on the cpu.
I'm now lost and am looking for an answer, please help.....
Thanks in advance, Axe.
checked
checked ram & micro.pro still i am not getting disply and beep sound plz give a nice soution
please get me this problem
intel p4
no beeps and no display in monitor only fan is moving
Hi Anurag here
I have a intel 845gvsr motherboard. I am not getting any display on
monitor I checked by removing the ram still no display, Only heat sink
fan is moving,
Please Help
i get the memory then i started to open the power, then the problem is also persist...please help this problem accordingly.....
I'm having the same problem with my Asus A4D laptop. I am going to clean the internals and test whether the system works with a subset of the hardware.
No beep and No Display on the screen and have tried to replace the Memory and also boot on the board without harddisk hooked up r floppy disk
my pc monitor is blackout and no beeps whaen i start up even my hdd is not spinningmy cpu fan is working what is the problem tell me what can i do pls help me
same problem I do have.
i will try to clean the mother..... and i will use a good memory... but my computer has no beep and no display
hi there, i got the same problem here..... no beep no display and only the fun is running. wat should i do ? my motherboard is a biostar.
yes, processor fan running but no display on monitor
Please describe the specifics of your problem below. We'll add
your post as a comment to Mantu's No beep,No Display on my monitor,only
CPU heatsink fan is moving problem, and notify you when a new solution
is offered.
My Computer also just display Intel Logo and does nothing after that. I have Intel 845 DW 1.7 GHz, SDRAM 256 MB original intel board
no display
Hi everybody,this is Rashmikanta from India.My motherboard is GIGABYTE GA-8I865GVMK.Presently neither I am getting any beeps after opening the RAM nor any display.Only CPU fan is moving.I am not getting POST screen too
I have the smae problem
No beep sound is there as well as no display after removing the ram from the motherboard in 845 motherboard
Hi everybody
my computer does not show any display. If you shut down and hit on the cpu, it may start sometimes. When we try to on the computer, the light on thekeyboard (LEDs) are not blinking. what may be the cause? can somebody help? prasad, india
No beep, no display, cpu fan running, power led lighting, no keyboard response .. post code 9.0 - mobo abit an8 32x, cpu 4600+ manchester, 2gb ram ... removed everything except psu, also changed psu from 450 to 600 still the same problem .. want to flash bios but how ??? please help !!! thanks, if any ...
same
I have the same problem too.
Some friends Help me
I also have the same problem, but some times it's working fine.
But i'm sure, some components not fitted properly (Loose).
I just shaked my CPU, then it's working fine. This is helping some time, not permenantly.
If any one knows, pls suggest...
i have the same problem: no display, no beepsound,fan is rotating, cleaned the ram ,and changedto another slot ,cmos battery also change . but the problem nt solved , what can i do?
i have the same problem, no beep, no display but the lights are on
this is khen from sti college tagbilran, philippines.i am having the same problem too. my monitor has no display and my don't even beep. the LED in the monitor turns back to orange after few seconds.
i am using ASUS P5PE-VM
good day everybody... please help my... my motherboard have problem,, no beep nor display in monitor only fan is moving....
I have my system configured with Intel G31 chipset motheboard, The problem is when i switch on my cpu, My monitor, keyboard, mouse are not responding, even the red light under the mouse , green light in keyboard is not working, Initial Beep sound niot coming. but my cpu processor fan is working, DVD Drive s working and sounds normal. HELP ME GUYS
