I was baking in both ovens this evening. After removing a baking sheet from the lower oven and closing the door, I could not get the oven door to re-open. I tried setting the oven to "clean" waited for the oven display to read, "Loc" then cancelled the cleaning, thinking the oven door might unlock. No such luck. It does not seem as tightly closed as when the "Loc" feature is on. For example, I can pull the door open enough to make the inner light turn on. I am not getting any codes. Everything else seems fine. Thank you for any suggestions.
Usually, starting with a COLD oven, turn the self clean on. Wait 3 minutes, then turn it off [cancel] WAIT 1 minute at least, do not immediately pull on the door. This should reset the lock sync. If you cannot get it open still, you may have a faulty sensor that thinks the oven is overheated, or at this point you could have a bent actuator rod from all the tugging!
SOURCE: Maytag Gemini Stove Code F1-4 (bottom door won't open)
F-1 error is a Temperature Runaway. It Maytag's way of letting you know that oven overheated. Nothing you have done but it may have shorted out the oven sensor or the keypad. Check the sensor and see if it's closed. If it's okay, replace the keypad.
SOURCE: maytag gemini gas stove
on the oval window of my gas stove, maytag it says 5 Ab my oven won't work because of this
