Question about Precor Exercise & Fitness
Precor 9.25i treadmill will not turn on at on/off switch. It throws a spark then immediatly turns off
When turning on at on/off switch, it throws a spark inside behind the power switch and flips off. Will not stay on.
    Top Expert:
  • Precor Master
  • 12,223 Answers
Der Sir;
The power switch is failure , you must Change the switch. You must be shure the some wires is Not loose, otherwise the wires will be touching the carcase causing the spark inside. Retight the wires or solder .You must inspect the main motor board and all the element around . If someone is burned or other wires is touching the carcasing producing the spaprk.
sincerely. God bless you.
ernesto cuadramanagua, nicaragua c.a.
Posted on Feb 29, 2012
3 Suggested Answers
SOURCE:
  • 14 Answers
SOURCE: ???maximum user weight for Precor 9.45i
Normally most home treadmills are 250-300lb user capacity.
Call Precor with your model # and S/N and they can tell you exactly.
Posted on Apr 29, 2009
maxtreadmill
  • 832 Answers
SOURCE: Noisy precor treadmill motor
that sound is due to the bearing failing inside the motor this is cause by capacitance discharge thru the armature thru the bearings. these unit can be rebulit I 've done plenty
Posted on May 14, 2010
Precor 905e turns off after i run at 10 mph for about a minute
When a running belt has excessive wear, it creates a lot of friction which causes the drive motor to work harder. When the drive motor works harder it will start overheating. If the belt is not lubricated periodically, it will ruin the deck, the drive motor, and cause other electrical problems such as tripping the breaker [after a while, the circuit breaker on the treadmill will need to be replaced.
It is suggested to lubricate the belt every month. At this point, you may need to replace both your deck and your running belt.
The following link will take you to our tech support page that contains some tips and videos on how to maintain your treadmill:
How to Lubricate Treadmill Using Liquid Lube Video
Jan 04, 2013 | Precor 905e 9.2 9.20 9.20s 9.1 9.2s Motor...
Precor 927 stuck in incline position
How long have you let it run for after turning it back on ? Some treadmills have a re calibration test built in and will incline to the max and work its way down. During this time you should simply walk away and not touch anything as it trys to calibrate its self. If not i will need more information on it
Oct 10, 2012 | Precor 927 Treadmill
My client walked on her treadmill without it turned on which makes it hard and good exercise but then when she tried to turn it on and use it properly it would not turn on at all. Turned it off and on a...
I have a ProLife treadmill with a breaker on it, the fuse may have blown it. You may try that, It would be next to the switch by the front of the the power cord. The front on the pic of this website, near the left bottom of cord or switch.
Aug 16, 2012 | Precor Exercise & Fitness
Precor 9.27 Control Portion Not Turning On
1) Reset the c.breaker from your house
2) See the c.breaker or blown fuse in your treadmill see the block diagram +c. diagram
3) Try again, and proof.
4) Test the main switch from treadmill, and replace if necessary for OPEn, see the diagram how to do it.
God bless you
Jun 10, 2012 | Precor 9.27 Treadmill
With a few more details I am sure we will be able to work through is issue together and get you back into your exercise program shortly. If you would please give us a call at 1-800-347-4404, one of our technicians will be more than happy to assist you. Please give us a call at 1-800-347-4404 Mon-Fri 6AM-5PM, except Thur 6AM to 3PM, Pacific time.
- Precor Customer Support Team
Feb 28, 2012 | Precor C966i Treadmill C 966i
My Precor 9.35 treadmill keeps shutting off. At first I thought this was due to use or it getting overheated. But, today I turned it on several times and it would shut off as I was walking on it. The...
Is it on an extension cord? Take it off any extension cords and make sure it's on a dedicated 120v circuit. No other items on the circuit. Also, how old is it? Precor made a bunch of the 9.3x series from 2002-2005 with an aluminum tail roller that can cause problems. Check the back roller. Is is silver and non-magnetic? if that's the case, you have an aluminum roller and you need to contact precor. If you're the original owner of the machine, they should warranty the replacement of the parts, if not, you'll have to buy at the very least a running belt and new roller.
Jun 21, 2010 | Precor 935 Premium Series Treadmill
On switch flicks off when electricity turned on
The switch is also a circuit breaker it tells me that their is a good chance your Motor Control Board is shorted and will need to replaced or can be rebuilt. Call National Gym Supply @ 800-496-7278 and ask for pricing for new or repair.
May 25, 2010 | Precor C956 Treadmill with Cardio Theater...
Precor 9.25i treadmill running backwards.
The power leads Black/red will determine the direction that the motor will turn. If the leads have been switched to the wrong terminals at the lower PCA it will run backwards even if the black and red line up when the motor is plugged in. Check to see if the power cable on the lower board is in the right configuration. I've seen the terminals get switched when a new lower board is installed.
Oct 07, 2009 | Precor Exercise & Fitness
Exercise & Fitness Logo
530 people viewed this question
Top Precor Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Tom Chichester
Bill Boyd
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
