Cars & Trucks Logo
Posted on Feb 28, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2007 chev cobalt changed battery now radio doesn't power on at all
Checked fuses any help?
raj somaiya
Level 3:
  • Cars & Trucks Master 5,370 Answers
  • Posted on Feb 28, 2012
raj somaiya
Level 3:
Answers
5370
Questions
0
Helped
3570617
Points
14579
For radio related problem, check the radio help links .Click the link below to go through its procedure:----- How to reset Radio code after car battery is died?
http://howtobyme.blogspot.com/2011/12/how-to-reset-radio-code-after-car.html
------------- Can car radio code block Passkey anti theft system ?
http://schematicsdiagram.blogspot.com/2011/12/can-car-radio-code-block-passkey-anti.html
How to wire new car Radio?
http://schematicsdiagram.blogspot.com/2011/12/how-to-wire-new-radio-on-1990-toyota.html
Radio Stereo Wiring Diagram?
http://schematicsdiagram.blogspot.com/2011/12/radio-stereo-wiring-diagram-for-1991.html
How to remove radio on Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-radio-on-acura-car-models.html
Where is Radio Fuse located?
http://schematicsdiagram.blogspot.com/2011/12/where-is-radio-fuse-located-on-2007.html
----------- After Market Stereo wiring?
http://schematicsdiagram.blogspot.com/2011/12/after-market-stereo-wiring-for-1999.html
car radio doesn't allow to switch to the XM Band to get the radio ID?
http://schematicsdiagram.blogspot.com/2012/01/chevy-car-radio-doesnt-allow-to-switch.html
No power to radio Scion Xb?
http://repairhelpcenter.blogspot.com/2012/01/no-power-to-radio-on-2005-toyota-scion.html
Radio has power but no sound?
http://repairhelpcenter.blogspot.com/2012/01/lexus-rx330-radio-has-power-but-no.html
Radio goes ON and OFF while driving?
http://technoanswers.blogspot.com/2012/01/radio-goes-on-and-off-while-driving.html
Town Car Radio stereo wiring?
http://technoanswers.blogspot.in/2012/02/lincoln-town-car-radio-stereo-wiring.html
Radio wiring diagram for Car?
http://technoanswers.blogspot.in/2012/02/radio-wiring-diagram-for-1997-lincoln.html
How to remove cd player from dash?
http://technoanswers.blogspot.in/2012/01/how-to-remove-cd-player-from-dash-on.html
This will help.
Thanks.
5 Related Answers
Anonymous
  • 5 Answers
  • Posted on Dec 30, 2008
SOURCE: Radio wont come on
did you check fuse # 14 in the underhood fuse box (power module) on the drivers side of the engine compartment?
I had this fuse go on our van. It is a 20 amp fuse...
good luck!
Anonymous
  • 50 Answers
  • Posted on Mar 28, 2009
SOURCE: 2005 chev cobalt
I am sorry, but the factory default radio in all 2005 cobalt models does not have auxiliary audio input jacks anywhere. I wish they did.
Thanks for using the fixya forums!
Anonymous
  • 215 Answers
  • Posted on Oct 04, 2009
SOURCE: What fuses are required for the 2007 Chevy Cobalt
Jeff , the type and amp fuse need for the brakes are listed on the fuse box cover, its is probably a 10, or 15 amp fuse
Melvin
St Louis
jamie
  • 1810 Answers
  • Posted on Jan 01, 2010
SOURCE: i changed the radio fuse in my 2006 chevy cobalt
was there a reason the radio fuse was blown
like you over loaded the circut with an air pump or charger of some kind or a penny in the lighter ???
Anonymous
  • 79 Answers
  • Posted on Mar 22, 2010
SOURCE: 2005 chev cobalt sputters at idle. Replaced knock
well i have got quite a few bad parts from autozone they just dnt make them like they used to hahah.....i say take that 1 back nd get another 1 if it still doing this then u can msg me at [email protected]
How to install a block heater into 2007 Chev Cobalt LS?
I`m surprised this didn`t come from the factory with a block heater already installed. if so look for an electrical plug like would be for a house hold lamp, somewhere in the area of the battery. if it didn`t come with one when you buy a block heater the instruction tell you were it is to be installed on the engine and position of element.
2007 Chev Cobalt LS
To do this you would have to remove a freeze out plug from the engine block
2answers
'No Vin' is on display of radio.
dealership has to reset radio code.some times owners manual will help.
Install a ELECTRIC POWER ASSIST SYSTEM on a 2007 chevy cobalt
Electric power assist is a recall on the cobalt. Take it to a Chevy dealership and they will replace it free of cost
1helpful
Radio display doesn't work
check the fuse if you short out your cig lighter it will cause your radio to loose total power
2answers
2006 Chev Cobalt won't crank...no lights, no sounds nothing. When tried to get the key out it won't go past the ACC position? Any ideas on the problem?
Is the battery dead? Check your battery condition and connections. Check your starter fuse from there. Check the connection to the starter then progress to the ignition side of the concern
1helpful
Radio doesn't work after battery change
check your fuses to the radio and check to make sure it wasnt wired to the battery direct
2007 chevy cobalt ls won't start battery good starter good turn key nothing no click nothing all lites work on dash and radio works jumped starter with screwdriver turns. Over but won't start...
Ignition relay or fuse could be the problem. When you turn the key to start do you hear a fuel pump kicking on and or do you have spark when you hot wire the starter (I know it's hard to check while trying to start it)? You can email me back and I might be able to pinpoint it more.
5helpful
2answers
Back up camera
I agree with Mike. The same thing happened to my 2007 Murano after I needed to get a battery jump -- my screen went black, no back-up camera, couldn't turn on radio or HVAC.
Brought it into my dealership who changed the battery, then they wanted to run a diagnostic (around $105/hr). I asked about the fuses, and thankfully, as it turns out, it was the "back-up battery fuse." Just paid for the battery and labor for that, and the fuse.
3helpful
2005 chev cobalt
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
