If i connectt he ethernet cable to my dlink router and not to the pc i have wifi. but if i connect it to the computer I have internet on the computer but not wifi. i do know how to make sure it is hooked up right, but i am not sure what to do. I have unpluged and restarted everything a lot of times and also reset the modem. What do I do
Hi. Let's hava look at what you are doing.
I'm guessing that you have a cable modem a dlink router with wifi and a computer, right?
If you connect the cable modem to the computer you have internet. You shouild also have wfi but the wifi will not give you internet because it is disconnected from the modem.
The Dlink has to be connected to the modem but it will also need to be configured. To *** that you will need help from your cable company.
The connections should be. Modem connected to the outside world. Dlink connected to the Modem. Computer connected to the Dlink by either wifi or Ethernet.
SOURCE: Connecting DLink thru Comcast Cable Modem and Vonage box
first you see the in the internt explorer in that tools in that is give internet option in that connection>lan settings> if the proxey server is ther then remove it if not ther then go it. i think you get it.
second think is that in your dlink router reconfigure the router properly and give the isp details correct and one more thing is check the dns value.
SOURCE: how to connect ADSL 2 modem to Wireless Router
just change the ip address in the router and give the proper settings in the router
SOURCE: Not able to configure and connect to internet using router
Manually configure the setting in your LAN, this could help.
Connect a LAN cable between LAN1 of your router then to the LAN port of your computer. Power the router.
Goto Lan settings, highlight TCP/IP, then click properties.
In your lan settings manually input IP address 192.168.0.52, Subnet 255.255.255.0, gateway 192.168.0.1
You can input also the DNS number of your IP.
Then open web browser type in the address bar 192.168.0.1. You should go straight thru router utility setup security log in.
This can also be set wirelessly. Leave comments if I miss something.
SOURCE: cannot get dlink 524 wireless router to work with HN9000
Hi! I will be more than glad to assist u in this concern..if u bypass the router it will work, the reason why the modem wont talk to the router bcoz the router is not properly setup.. if you are using a cable modem from ur cable company provider- u need to do a mac clone on the router u have to clone the mac address of ur computer. normaly the mac of ur computer is the one register to your cable company and on the setup page of the router just selct on the internet setup, dhcp after clonning the mac address of your computer. u need to connect ur computer directly to the router and then after doing the process connect the router to the modem. if u are using a username and password, u have to use the pppoe settings on the router, if ur isp set a static ip , set it up to the router, to check the ip setting of your isp.. connect the computer directly to the modem and check if u have internet.. then click on start, run and type cmd,it will give u a dos prompt and from there type ipconfig/all and it will show u the ip address, subnetmask, default gateway, dns server.. I hope this will solve ur concern..
SOURCE: HOW TO ACCESS DLINK WIFI ROUTER BECAUSE OF FORGOTEN PASSWORD
We have a Dlink 615 Wifi Router,I couldn't set a username and password to prevent it from illegal usage.We have a cisco 1700 router. Can any one help us in installing a username and pass word for our router.
