Hi there, When it says that the destination list cannot be used right now, it means that the HDD (hard drive) where your scanning/faxing addresses is stored is corrupt, this normally happens when there is a power failure/switch off while the printer is accessing the hard drive. Press the yellow button, then 1 0 7, then hold the stop key(red/orange button) for more than 5 seconds until the screen changes, select the first option which should be "copy" or "system", then press 5 8 3 2 #, then select "execute", this will format the HDD/hard drive, then switch off and on, input your addresses again and all will be fine.
If you are using an LDAP server to provide the destination, you may not have the Search Conditions programmed correctly.
SOURCE: i need ricoh aficio mp 1600le driver, how do i get into.
Here is the driver page:
http://www.ricoh.com.sg/downloads/drivers1.aspx?path=http://support.ricoh.com/bb/html/dr_ut_e/ra/model/mp16/mp16en.htm
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: ricoh aficio 1018 printer
yes you have to install the drivers and give the usb option for communication
SOURCE: Printer shows offline/Scanner has no destination list
You must program the email addresses in the machine address book, so that you will have a destination list to scan to email.
You can also try to scan by pressing the Scanner button to access the scanner function and input the email address manually by selecting manual, and then press the Start button to scan the document.
Joe
SOURCE: HOW TO REBOOT RICOH AFICIO 1515MF??
need to enter service programs print out 5990-2
then exe 5801 memory all clear
put all the settings back to where the were set
the printout will show you default and current settings
SOURCE: can ricoh aficio cl3500n use glossy paper that is
Ricoh recommends heavier paper be run from the
bypass tray 16lb to 53 lbs are the recommended weights
