Zanussi ZWD1680W Front Load Washer / Dryer Logo
Posted on Aug 03, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Too many E20 errors!
I have a Zanussi ZWD1680 machine in my flat and it is ridiculously sensitive. I rarely get through a wash without having the E20 error come up and frequently after I restart it, the machine does nothing for 5-10 minutes before going back to E20. It does not even try to re-spin. If I am not paying close attention, a load of clothes will take hours to finish due to these frequent stops. Please help!
paul
Level 3:
  • Master 825 Answers
  • Posted on Aug 03, 2017
paul
Master
Level 3:
Answers
825
Questions
0
Helped
174008
Points
2202
The first thing i would try is the pump..........if its not draining all the water out it will take longer to finish...........pump could be blocked......alst the hose from the pump........check both first.....
cheers
4 Related Answers
Colin Stevens
  • 17 Answers
  • Posted on Dec 17, 2008
SOURCE: zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Anonymous
  • Posted on Feb 08, 2009
SOURCE: ZANUSSI WASHING MACHINE
I have taken out the filter and washed it thoroughly! Also flushed the out pipe to make sure the whole system was clean. This resolved the problem
Anonymous
  • 53 Answers
  • Posted on Nov 01, 2009
SOURCE: Error E20
zanussi error E20 suggests a pump/draining problem. remove pump/filter and clean it all out. its located at the end of the drain hose at the bottom of machine. power off. it might need replacement.
Testimonial: "Thank you so much - exactly right"
kapishtech
raj somaiya
  • 2272 Answers
  • Posted on Sep 01, 2010
SOURCE: Hi, my washing machine is
The drain pump and filter jammed.error E20.The drain pump getting blocked. Plug off the mains. You have to look for screws below the front kick-panel, you can raise the machine a bit to gain access to the screws, the panel comes down & out. You may find a drain hose here, on left, drain off the excess water. The pump is on the right side. Be prepared for dirty water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out.Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter. cleaning the filter is no easy task.
1. First, make sure you have super glue on hand, the door seal is glued to the front panel, will have to be removed first then glued back in place. Using a sharp knife, carefully begin peeling the door seal and cutting the glue close to the cabinet. Do this slowly as to not damage the door seal.
2. Remove top cover. Screws are in the back
3. Remove control console.
4. Remove screws securing the door lock. Remove all front panel screws. Remove front panel.
5. Attached to the tub there is a large, fat drain hose, inside the hose you will find a filter.
Check fig:- d735953.jpg
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Zanussi Lindo 300 repeatedly has drainage issues, get code E20, E40 or E41. Cleaned filter out, no objects stuck or water - what next?
https://www.zanussi.co.uk/support/support-articles/laundry/washing-machines/washing-machine-does-not-drain-displays-error-message-e20-e21-or-c2-emits-2-beeps-2-flashes/
I have a zanussi jetstream 1400 washing machine and have error e20. Despite trying various settings to kickstart the machine, it will not drain the water. Ive cleaned out the filter (i do this regularly...
E20 means problem with drain water phase
Only two things need to be checked:
- Drain pump could be clogged or no power supply (the last means
faulty drain pump, faulty electronic or wiring between drain pump
and electronic.
- Your home drainage system (in the wall) is clogged (This is very
easy to check visually, disconnect the drain hose from your
siphon and put water in some container or in washbasin.)
Dado
2answers
I put on a load of washing and it stops half way through the machine flashes E20 n just stops the machine is a zanussi jetsystem zjd12191
Error code E20 relates to the pump/filter blocked.Drain the water either manually through the filter or drain hose.Check that filter is clean and pump can turn by hand.
Hope this helps.
11helpful
Error E20
1helpful
Error code E20 comes on during a wash cycle. i
If the filter is clean and the hoses are free of obstructions,you will need to replace the pump
2answers
11helpful
Error message on washing machine E20
E20 is "A problem with water draining"
Solutions:
The drain hose may be squashed or kinked
the drain pump may be blocked
or possible your filter is totally blocked. Clean out the filter everything will work again. Put a large bowl under the filter as you unscrew it; a fair amount of water could be there.
Good luck.Please rate the solution if accepted, also do post comments in case of any doubts.
2helpful
2answers
Zanussi
E20 = Problems with water drain in wash phase ALARM CODES E20 Is the drain filter clean; Problems during draining phase (Machine tries to drain for 10 min without emptying the tub) Checks to do: E20 Is the drain pump working? Is the value of the pump about 200Ω? (Measure directly the connector by the board, between J2-2 and J2-7) ; If No Change the pump and run again Clean the filter; Is the draining system OK (drain hose and plumbing where machine is connected) Free and check the draining system; Is the pump blocked? Is there any burn mark on the control board; if yes Change the board E90 = Communication error between user interface and main board. Verify the connector between the main board and user interface board by plugging and unplugging the connector few times on both sides, OR replace the blue ribbon cable. The fault could have been caused by oxidized contacts in user interface plugged in the main board. Kind Regards David Marsh
18helpful
4answers
Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Top Zanussi Washing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Mike Cairns
Mike Cairns
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
