I put a 3n1 start on it and no difference
SOURCE: temp -35 degrees,freezer runs all the time
I assume there is no manual control for setting temp. so the thermal sensor or control circuit has failed and it is just staying at its maximum.
You will probably get more help from the manufacturer but their website is somewhat disjointed; looking for contact info for your product ends at one point and then shifts to their scientific product line.
The only general contact info I found is here:
Nor-Lake
You will in any case need to have the correct model number at hand since the subject line doesn't sound like your freezer.
SOURCE: Master-Bilt Freezer doesnt cool enough
The only thing I could suggest is looking at the evaporator (inside coil / cold bit) and making sure it is not frozen over reducing the airflow through the coil. If it is then put it onto a couple of defrost cycles to clear the ice build up. Not sure exactly of this type but would assume you also have a sight glass on the external unit, you can check this to see if when running the sight glass is clear (fully charged). Another check is looking at the compressor and the larger of the two lines (suction) should be cold back to the compressor (this line is normally insulated). However I would suggest your best course of action is a good refrig. techy. Hope this helps.
SOURCE: temp
jtcarlier
20 Degrees is good
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
SOURCE: kenmore chest freezer
If your chest freezer is less than 50 years old, it does not have a fan. Cooling coils contact inner walls of freezer compartment, warm coils dissipate heat through outside walls of freezer. If compressor runs, temp is 30+ degrees, gasket is OK, lid not left open, then you have one of two contions: 1. Low capacity compressor 2. Refrigerant leak. Solution to either is to replace freezer. (My opinion: Don't get a Kenmore brand, which generally ties you into poor warranty and slow and poor service.) No matter what brand name is on the freezer, it is most likely manufactured by Electrolux (in St. Cloud, MN) or Haier (from China). Look at the model / serial number plate before purchase to see where it was manufactured. Yes, the USA manufactured ones are better. (and I'm not just saying that because the plant is less than 15 miles from where I am sitting right now)
ice cream is always the last to freeze and a temp of minus -10 degrees is usually required to get it to get hard. if you put the ice cream in the door it will be especially tough to freeze. a good thermometor is a good investment as you can observe the temps. usually ten degrees or 20 degrees is what they run. yes they do cycle on and off as long as they hold temps thats good. the outside of the freezer gets warm because the hot compressed refrigerant is spread through piping near its surface giving up its heat of compression . setting the stat to max will freeze the ice cream eventually but utility bill suffers . good luck
