When I turn my Pixma ip4200 printer on, the green light is on, but the resume button light(yellow) blinks five times. I got an operator error message to turn the printer off, then turn it back on. I've done this several time, even unplugged it. Any help concerning this would be greatly appreciated.
A repeating 5 orange flash is supposed to mean a foreign object inside the machine interfering with the print head. Check at both ends or the carriage track for a crumpled up wedge of paper. If nothing is there, check down the back paper feed path. If still nothing, it is possible the print head is overheating and is about to die.
SOURCE: Canon PIXMA iP4200 won't print
I solved the problem (I hope more than temporarily) by going out and buying a new yellow ink cartridge. The new one seems to be working, but the cartridge that generated the error message was brand new, too - hardly a satisfactory outcome. I worked out that buying a new cartridge would be slightly cheaper than signing up for one of the Canon support plans. As you can guess, this experience does not augur well for me buying more Canon products in future.
Roslyn
SOURCE: canon service erore for Pixma IP4200
the prob is in the sheet feed unit, im afraid you cannot repair this pls send to repair shop asap
cheers
SOURCE: Error number 6A00 for Canon Pixma IP4200 Blinking
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: canon Pixma IP4200 started printing regular
Hello first of all are you technical
I have taken the printer head out
boil some water and pour in a cup
take off the 2 screws at the bottom
gentley open the head from the casing**** note if you not gentley it wil brake and U can through the hole head away
then let the white block lie in in the water until the water is cold the trough that out and repeat this step.Boil water again....Wait for 4 to 5 minutes to pass..... then use high copressed air and blow from the underneth so that the presure will force the **** out on the white block side also force some hot water from the litle sifes at the top down and make sure that holes are open
replace the ruber perfectley and the head pease an make sure every thing is propeley dry.Replase the scews .and put it back in the printer.Remember it is also a very filthey and inkey job.Good luck
SOURCE: canon pixma ip4200 green &
You might need to reset your printer so it can work again. please follow the steps below. It is important to familiarize yourself to the steps before doing it.
Here it is.
With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold the Power button.
Do not release the buttons. The LED light should be green to indicate that a function is selectable
While holding the Power button, release the Resume/Cancel button, do not release the Power button
While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.
When the LED light is green, press the Resume/Cancel button 4 times. Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.
Press the Power button. The LED lights in green, and the reset is performed.
When the operation completes, the printer returns to the menu selection mode automatically
Press the power button to exit service mode.
Hope this helps.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Thanks, Joe
