Question about AcerView F51 15 in. Flat Panel LCD Monitor
Monitor goes dead AL1914
I have an Acer LCD AL1914. It is 14 years old and has CCFL back lamps and fails on 2 PCs, and the cable is not bad. I am told another CCFL 2003 monitor bites the dust, is it?
  • Anonymous Mar 31, 2008
    Exact same problem on my AL1914.
  • Anne McClusky May 29, 2008
    I have the same problem. Turning the monitor off and on over and over it will finally stay on. worked a few times after rebooting now won;t come back on at all. Just will flash for a second showing the desktop. I was told it could be the video card. I will try changing the card this weekend. I have a viewsonic monitor though.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 45 Answers
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Posted on Mar 17, 2017
  • 2 more comments
  • Anonymous Feb 20, 2019
    actually this is more easy.
    that old monitor has bad CCLF back lamps.
    all do this old. (age matters here)
    if the monitor fails on 2 PCs the monitor and sure the cable are bad.
    1 test and no more silly guessing .
    no manual at acer.com now.
    but shows 2003 year stamps. oops PRE LED era.
    but the main PSU board for it clearly shows CCLF power jacks
    the older monitors have (pre 2010) had a monitor sleep timer inside, we turn that off first, setting monitor to defaults in the oSD also turns this silly old sleep timer back on, yah silly.
    I found a manual in the dark web
    shows no sleep timer INSIDE it. GOOODDDDDDD
    The trick is use a flashlight.
    buy one use one.
    point it at the black screen in a dim room
    see data how, bingo, CCLF ***** has arrived
    as all are now every one, no parked in attic for 5-10 years.
    https://www.manualslib.com/manual/1068/A...
    the magic of a $2 flashlight test is here
    http://www.pcdied.com/monitors_and_scree...
    it's now 16 years old. (a good run be happy)
    2003 to 2019
    so buy one 2010 or newer and CCLF are gone and LED runs forever mostly.
    back lamps topic.
    ALL CCFL 2009 and older monitors are dead now. if used 8 yours a day for 5 year the CCFL tubes (trash lamps) die.
    they go dim
    or dead.
    go yellow
    blink.
    or work one day not next or 1 hour and not next. all do that now.
    we put them out to the trash,
    or spend 2 times cost of this.
    $46 gets you one that is good.
    https://www.walmart.com/search/?cat_id=0...
    Buy only LED monitors, OK>?
2 Suggested Answers
paulbtorrent
  • 34 Answers
SOURCE: ACER AL1914 LCD Monitor goes black but green light stays on
The monitor is doing a self test a finding an error.
The lcd has three parts, the screen plate(windows)/the logic(vga)/the inverter(power plug). Parts that go are the backlight ccfl's, behind the plate, and parts of the inverter, ie capacitors, all three take a bit of power from the inverter. The self test check that all the lights are ok and the inverter is ok, else it switchs off, ie if 3/4 light work it will switch off(my own case), hence the on chech error then off, However sometime there are stages of on/off ie on/ but no screen display, if that is the case the following may be of help...if you put bright light at an angle close to lcd can you see a windows shadow, text icons etc, ie still logic power passing,then .... (from a.n. other) after two weeks searching I finally find doctor living stone http://www.aplusperfect.com/articles/lcd_capacitor_repair more fun with paulbtorrent
the takening the case bit off is like opening your wallet a second time after buying a new LCD, but you must! smallest two screw driver's flat headed, practice using two pennies stuck together()with your fingers after, one little () move and inch and {} again, with the case , it does not break, just need to lever open
[once open you realize they somehow put that old briefcase clip inside!] also note the bright light test to do first to see if can see a windows screen , and that capacitors are one for a number of things that a make a inverter work! there a transistors as well, given that however, to replace all the capacitors on my inverter, was 11 capacitors, cost me $11 (uk ebay) and already had the iron and solder. So only cost me me $11 to try and see but no luck , still fun and I still can see the screen for 2 sec' at a time plus I have a spare set of caps now in the event that the new one do go burst! you have to laugh really, what next , a new on/off button, as you work though the whole inverter mmmMMMMmmmMMMMmmmMMMMTim Berners-leeMMMMMmmmmMMMMMmmmmcome back all is not wellMMMMMMMMMMnnnnnnweek later land sight mmmmmMMMMMMMMMmmmmgggggggg(from
another a.n other)Generally, if the screen went out quickly, it was the inverter. If it went out over a slow period of time (flickering etc..) I would bet it is the lamp.replaceing the lamp should be pretty challenging. as that requires complete breakdown of your LCD, extraction of your dead lamp, and soldering in your new lamp... but I would like to say that I it did this after realizing it's 2 x kitchen strips inside [========] with wires that can connect back to the inverter with out any desoldering(ie kit assembly/dis) with the outter case remove (glass plate safe away) I could reconnect and see that 3/4 were working (i!i hardcard ) cause the inverter to switch off after a secound ! order bult and replace and going
to cheap and see if I can get away with fitting a 15" in my 19' as it a 1/3 of the price ! the market as drop out there, hope the inverter does not miss the length, or the screen out put.http://www.lcdparts.net/howto/troubleshooting/LaptopCCFL1.aspx OR MONITOR
Posted on Feb 08, 2010
Why does my monitor HP L1740 post a picture for a few seconds and then shuts off. only py turning the monitor off and on manualy it posts again but for only a few seconds. i have it opened up already.
if the monitor fails on 2 PCs the monitor has hardware issues, does it?
costs not a dime to plug it into friends PC with vga cable.
you said IT Shuts off,? does that mean.
the power button, has 3 colors, led status
off black led.
on green led.
amber led, sleep.
is it light going out?
or just a screen black,
if just screen black does OSD work on demand
yes, no?
if yes the monitor is not dead.(not totally)
if no it is dead.
seems your PSU board inside if bad, if the monitor goes dead.
Old monitors 2000-2007 had sleep timer.
disable that junk now.
seems it is a bad monitor, but id have to see it
and do many tests to condemn it.
Most of these monitors died long ago.
CCFL deathh(sic).
The first ones made in 2005 so is 13 years old.
Nevers seen one this old good.
CCFL failures are classic and super COMMMON.:
dead,
blinking (strobing effects)
yellow for white screens
dim
Sep 22, 2018 | HP L1740 17" LCD Monitor
Acer Aspire ,5535 black screen,on/off button ok,...insert dvd searching??power light on, batt charging light on,fan on..where to go next
ok, 10 year old laptop
step1 , as always remove the old dead shorted huge battery first.
run now? it will on AC for every if you want.
Led Glowing tell not much its just and LED, so dont look at them if on, unless and LED blinks codes. ok?
what matters is power, power is first. no power no joy, ever.
so out the battery now.
Put in a new RTC coin cell battery next 7 year life rated you are 3 years past that at 10 years old, (end of useful life that)
next is fans, , ok fan is on.
next is what, TEXT got TEXT ON SCREEN>? ANY THING??
I guess ZERO SCREEN anything of any kind>.
we next use a flash light, this PC has crummy , CCFL back lamp tubes that when dead screen goes, dead, as most have this old.
only few never used laptops last 10 years old.
so with the flash light (dark room) at an angle shin the LCD
see data, now on the screen, yes, that is a DEAD CCLF.
on ebay you see them selling new CCLF screens for this PC.
my bet the CCFL are dead. as most are this old.
All laps this old fail in this order,
BIG battery goes bad or shorts.
COIN cell dead.
CCLF dead ( ended about year 2010 , LED back lamps began)
HDD dead at 5 to 10 years old.
this is all Expected. all from carbon14 dating a PC, I can say that.
yours is 2008 made.
Aug 17, 2018 | Acer Computers & Internet
White screen after about 20 minutes of operation
key words above, (change(d) PC) did you mean you changed out the PC, and it fails, I will guess yes) as in past tense?
old old , 1710s, most are now dead, you know that right?
all have CCFL tubes in it.(problematic for sure)
and had a sleep mode inside, (problem 2) sure.
so with PC turned on, the push the menu key
and turn off the sleep timer, keep it off for ever.
it is not compatible with NEWER PCs at all.
the Monitor is bad,
if cable and pc are ok, the monitor is bad.
you proved that, if change = changed. above.
like this. (GO LED !) avoid all monitors older than year 2010 !
https://www.walmart.com/ip/Asus-LCD-VS197D-P-LED-Backlight-18-5inch-Wide-1336x768-50000000-1-5ms-VGA-Retail/20701019
Nov 06, 2017 | HP L1710 LCD Monitor
When I open HP MY DISPLAY software it doesn't work. It looks full black. There is no menu or option. It shows blank. So I can't tune display color or any other things. I uninstalled it. Then I...
HP W1707 LCD Monitor circa 2008 old. 10 years old NOW.
No PC stated or any OS at all. windows what?
connected to what? it must be connected to a working PC
or the monitor is useless as 3rd shoe.
i can only be 2 things, PC or screen bad.
  1. the test is child easy test the monitor on another PC.
  2. or test the dead PC on another good monitor.
the monitor has no software ever.
only the PC side does for the PCs video chip GPU driver.
but the PC always has one, even if, poor quality resolution.
Toss magic coin land on bad w1707
The screen, can fail for many reasons lets say it fails on a good PC. known good.
these old monitors have CCFL lamps that love to fail inside.
It has no LED back lamps , before 2010. it haS CCFL lamps.
The monitor all by its self, pc disconnected.
you power it on and it shows logo, HP or Compaq
then for seconds turned on the menu may work.'
if you see nothing the CCLF are dead.
The menu button works only with good running PC. but
might work for 1 second.
some do others dont but only for seconds does the OSD work
lacking a good PC connected.
the OSD is the menu from the monitor brain inside
the button is called select or menu.
PC turned off and Monitor now turned on the screen shows.
if the PC is dead the Monitors brain then shows.
NO SIGNAL , or NO sync.
or if PC is set up wrong the monitors shows, OUT OF RANGE.
CCFL love to fail.
the lamps turn yellow, blink or go DEAD.
as can the HV inverter seen here.
http://www.pcdied.com/monitors.html#Inverters-monitors
PAR:
i one uses the monitor 10 hours a day
on the 5th year, the CCFL goes dead. that is there normal life span.
Dec 27, 2017 | HP W1707 LCD Monitor
My flatscreen monitor (HP w19b) kept powering down. I would push the on button, and it would go on then power down after 10 seconds. This morning it wouldn't go on at all for about 1/2 hour, then started...
Hi sir, try to check for possible leaking or bloated filter capacitor in power supply board. That symptom might be caused by insufficient current draw from power supply source. Try to check sir. Maybe it could help. Thanks!
Feb 14, 2018 | HP W19b LCD Monitor
HP LP2465 monitor is a secondary screen attached to my laptop. Has worked for more than a year no problem. All of a sudden the monitor has started flickering. The display is fine for 1-2 seconds then...
you did all that but the acid test.
does it fail on ANOTHER PC<
if yes,them monitor is bad.
all do that, LP2465, all do.
if the monitor passes the acid test.
then the 2nd port on this PC unstated is bad, on the unstated video card. or its drivers bad. or OS corruption.
im sure you moved the dvi cable left and right on video cards
to see if the video jack was it.? right?>
the monitor has 2 DVI ports, try both?(it auto switches inside)
this monitor is 10 years old, 2007 (oldest) carbon14 dated.
as such back then, we did not have LED screens yet.
History matters.! in all cases. of electronics.
until 2010 but some did just before only the top models big.
i read your users guide, the 2 clue2 there, are
"this extends the life of the back lamps"
ahh but page 41..... is better.
http://h10032.www1.hp.com/ctg/Manual/c01446650
the tubes have Hg. mercury inside, BINGO FOR CCFL for sure.
CCFL all do this.
goes yellow
goes dead
goes, dime
goes blinking or completely intermittant.
all do that, even in 2 years, in presentation mode, (on all the time)
CCLF BLACK LAMPS ALL DO THAT
and lasting, 10 year is , kiss the tooth fairy moment,
looked in the HP parts surfer, no parts in stock related
the monitor dead is worth $20 used.
so if it really is bad, then fixing it would cost 2 times
a new monitor, $75 new.
I could not find parts for yours, anywhere, see what LCD is actually there was not easy to discover.
2010 is the end if CCLF, is all I know, unless parts support exists.
https://www.walmart.com/search/?cat_id=0&facet=screen_size_monitor%3A24%22+-+25%22&query=computer+monitor&sort=price_low#searchProductResult
Oct 16, 2017 | HP LP2465 24" LCD Monitor
My monitor is about 6 years old. Some weeks ago, when I powered on, a grey streak started appearing and moved top to bottom before the normal image came on. Lately, the monitor blinks on and off when I...
2003 is the first one made, 14 years old it sure can be.
new to you sure,.
all monitors, from 2000 to 2010 year, are backlighted with
crude CCFL maps, that last for 2 years (shortest life full time)
the all go bad, ever one , if USED, lots.
they all: endup soon.
1: dim
2: yellow tubes.
3: flicker ands strobe (not the data just the back lamps)
4: dead.
5: totally interminttant.
just like the forecent lamps im garage and for the same reasons.
6: the osd goes dead to when above happens. menu key on monitor front, but not data seen with flash light trick.
learn when 4 happens, above, do this.
http://pcdied.com/monitors.html#flashlighttest
manual.
https://www.manualslib.com/manual/30069/Hp-F1523.html#manual
buy monitor 2011 and newer, and this pain above goes byebye
at the introduction of wonderful, LED backlamps.
Oct 16, 2017 | HP Compaq FP 7317 17" Flat Panel LCD...
HP F1903 monitor
sure the F1903
is a LCD monitor but is old , it has
and CCFL black lamp.
it has board inside that is the power supply /inverter
this board runs the lamps.
the lamps love to fail after 10 long year of service
so when monitor fails, push the menu botton on the front
is the OSD menu dead (monitor brains inside)???
see bottom of this page , see CCFL and PCB there?
if lamps bad replace them
if PCB bad replace it, seen sold on Ebay , vastly, there.
http://pcdied.com/black-screen.html#CCFL-examples
some of these old monitors.
have silly internal sleep mode,
turn that off. (push menu button on front)
see OSD (on screen,display menus)
see settings
see power saver mode, turn it OFF,
Jul 28, 2017 | HP Pavilion F1903 19" Flat Panel LCD...
AcerView F51 15 in. Flat Panel LCD Monitor Logo
80 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
