SOURCE: Ink Failure on HP photosmart premium C309g printer
Turn off the machine, unplug the power cord from the back of the machine, remove the ink cartridges (lift the lid up at the base of the control panel), wait 2 min, plug the power cord back in, press the on button, wait until the printer prompts that the ink cartridges are missing, then replace the ink cartridges. If this doesn't fix the problem you may have to re-prime the ink lines to clear the error. You can find instructions for this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
SOURCE: every once in a while I can not print with my hp
try to reinstall the printer driver software then restart the computer and printer. you can download the printer driver software from your printer manufacturer's web site.
SOURCE: hp photosmart premium model c309g. paper is being
you likely have a small piece of paper in the paper path, or a small object. Some of the paper path cannot be seen without dismantling (which I don't recommend)
It can be difficult to find someone to repair it, and HP's solution is to convince you to 'upgrade`
SOURCE: I have a HP Photosmart
An '0x ...' Error Message Displays on the Front Panel When Printing HP Photosmart C5380 All-in-One Printer - HP Customer Care (United States - English).
If you need more help post back!
Thumbs and testimonial are welcome!
