SOURCE: how do I replace the tail light bulb on my
ok cadillac for some reason has to be difficult about these things you actually have to take the whole tail light assembly out. . .here is what youre going to need:
1. socket wrench
2. number 10 socket (gm's nut of choice)
3. patience because it is easy to drop the nut be careful
ok so you have to open the trunk then take the plastic that holds the carpet down off. you do this by unscrewing the black screw on pegs (not sure what to call these things). after you do this pull the plastic thing hard because it is being held in place by some pegs other than the ones you have already removed. then remove all the side carpeting depending on which side youre changing. ok after this look directly behind the tail light assembly for 2-3 (i forget how many) bolt like pegs (my new favorite word) these are attached to the plastic tail light assembly. then take the nuts off of these pegs and then you should be able to tug the assembly off. then you do what the others say take out the socket and replace the bulb.
like i said cadillac makes **** hard to do. if you hate this wait til you have to take the whole bumper off to replace the headlight bulbs (might want to invest in some hid lights so you wont ever have to replace them)
good luck
SOURCE: Replace 2005 Cadillac CTS water pump
drain the coolant.remove belt by rotating belt tensioner cllockwise. water pump pulley will require a holding tool to keep it from turning while removing bolts. access to air ratchet can sometimes eliminate the need to hold but be careful cause thats a good way to skin some knuckles. also make installation more difficult to obtain proper torque. after pulley is off just a few water pupm mounting bolts remain. clean and dry gasket surface very well before reinstalling.
Testimonial: "Very quick with a response, and good info!"
SOURCE: HOW TO REPLACE A BREAK LIGHT SWITCH
The brake light switch itself is located on the brake pedal follow it down until you see where it connects and unplug the connection ...after installation make sure the brake light switch is correctly adjusted by having a 2nd person stand behind the vehicle as you press the pedal the light should come on if not adjust the switch higher up by turning the switch inward ..or upwards by screwing it in if it constantly on unscrew it until lights go out and its fairly easy once you actually look at the part and the pedal ...i hope that helps you
SOURCE: how do i remove a stuck CD in the 6 CD Changer for
The best way would be to remove the player from it's current location and remove the cover from the player.That is,if you're wanting to salvage the cd.If you're just needing to remove it,this can be done with a fingernail file or a typical letter opener.
SOURCE: My cadillac cts 2004 airbag service warning light
check ther wiring connections under the front seats clean them with a soft lead pencil ,if that doesnt work then remove the dash ,cut the feed to the bulb and connect the feed to the oil light bulb so when engine starts the light goes out so it passes the inspection every year
