Car Audio & Video Logo
Anonymous Posted on Feb 26, 2012
I can not get a 12vdc signal from the sub remote out wire blue with white stripe on a NESA 749nb, at one point I had power on the wire but when I got itr hooked up the power went away, I need a signal
If i supply a 12vdc to the sub remote lead it turns on so I know the sub is working, and I checked the wire output with a multi meter
Pablo Gonzalez
Level 3:
  • Master 733 Answers
  • Posted on Feb 27, 2012
Pablo Gonzalez
Master
Level 3:
Answers
733
Questions
0
Helped
266206
Points
2189
If the head unit has any fuses go ahead and check those. Recheck all the wiring to make sure nothing was connected where it should't. If you still can't get any power out of the remote wire, there might be an internal issue with the head unit and if it's under warranty, take it back. The only other option is to use the red accessory power wire on the head unit and tap into that but the only thing is that when you turn off your radio, the amp will still stay on and will only turn off when your vehicle is turned off. I would prefer to have the head unit control the amp, so if it's warrantied take it back, but it's completely up to you.
Hooking up kenwood cd player in a 2000 silverado but the wires aren't labeled coming out of the cd player. Pls help
If you use a wire harness adapter, you just have to match the colors from the Kenwood plug to the wires in the adapter. No guesswork.
Kenwood uses the CEA standard for car audio wiring:
Yellow: 12VDC constant power
Red: 12VDC key-switched power
Black: Ground
Orange/White: Illumination
Blue/White: Remote output for amp turn-on
Blue: Power antenna activation
White: Left front speaker (+)
Gray: Right front speaker (+)
Green: Left rear speaker (+)
Violet: Right rear speaker (+)
Each wire with a black stripe is a negative speaker output.
You can download owners' manuals from Kenwood's web site.
http://manual.kenwood.com/en_contents/search
1helpful
Why does my subs only work when the mode is on fm
sounds like you are using the antenna remote wire (blue) to turn the amp on. you need to use the amp remote wire(blue/white stripe). when you go to cd or any other function besides tuner power is shut off to the antenna remoter wire.
I just installed a sub and it only is working for
there should be two blue wires. one solid blue and one with a white stripe. if i remember the solid should be antenna remote and the blue with white stripe is the amp remote turn on. if you are using the power antenna,it will turn off the amp when not in radio mode.
2answers
I NEED FREE DIAGRAM OF CAR STEREO AND AMPLIFIER
Yellow: Constant +12VDC (memory)
Red: key-switched +12VDC (accessory)
Black: Ground
Blue/white: amp remote or power antenna output
Speaker wires: The solid-color wire of each pair is positive; the black-striped wire is negative.
Left front: white
Right front: gray
Left rear: green
Right rear: violet
3helpful
I need wiring diagram for pioneer deh p56
Pioneer follows the universal after-market color code, so if your CD player was made in the last ten years or so, the wires should go like this: Yellow: Constant +12VDC (memory) Red: key-switched +12VDC (accessory) Black: Ground Blue/white: amp remote or power antenna output Speaker wires: The solid-color wire of each pair is positive; the black-striped wire is negative. Left front: white Right front: gray Left rear: green Right rear: violet
9helpful
Can not find a wireing diagram for a pioneer DEh-p2600
Black: Ground
Left front: white
Right front: gray
Left rear: green
Right rear: violet
Hope this helps!
I need the wire diagram
Black: Ground
Left front: white
Right front: gray
Left rear: green
Right rear: violet
Hope this helps!
7helpful
2answers
Wire diagram pioneer deh-p7200
Black: Ground
Left front: white
Right front: gray
Left rear: green
Right rear: violet
Hope this helps!
My wife bought a kenwood z828/uf4. there are wires in the back but none of them are labeled. can anybody help me
red - 12v ignition
yellow - memory 12v cont.battery
orange - illumination
black - ground
white- front right speaker +
white/black stripe - front right speaker -
gray - front left speaker +
gray/black stripe - front left speaker -
violet - rear right speaker +
violet/black stripe - rear right speaker -
green - rear left speaker +
green/black stripe - rear left speaker -
blue - remote, amp
blue/white stripe - power antenna
if you don't have a blue/white strip wire than the solid blue wire goes to power antenna, amp and remote...........
hope this helped you
Powered subwoofer wiring
Red = 12v power Always
Black = Ground Allways
Blue = memory wire that has to run to a Amplifiers Memory Terminal
2x White, seems to be the dimmer and Ant, but im unsure as of these two,
Rca's will go into the AUDIO out of the cd player RED and White holes, that will go to your amplifier.
Im unsure if your talking about a Cd player here, but it seems this it is. If so you should have color coded wires for speakers also (ex- green, green with white stripe, Yellow, yellow with white stripe )
Please provide more information if this dosent solve your problem
Thank you
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
