HP OfficeJet 7310 All-In-One InkJet Printer Logo
A
Anonymous Posted on Feb 26, 2012
Error code 0x07a74dd6 and 1959:lib_barracuda.c
Blue Sky
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 06, 2016
Blue Sky
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2741
Points
Full Reset:
1. Tun Power OFF
2. Wait for 10 secs
3. Turn Power ON while holding 6 and #
4. Continue to hold until a reset notification pops up (be patient).
Note: The error may display again; just unplug and plug the power cord back in and you are good to go.
2 Related Answers
Anonymous
  • 1478 Answers
  • Posted on Sep 02, 2010
SOURCE: My printer is jammed. Carriage does not move.
I will advice you reset the printer, follow the steps below to reset the printer,
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold “# and 6? keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
If that did not fix the problem, try this,
  1. Unplug the power cable from printer while the printer is powered on.
  2. Press and hold OK and HELP buttons while plugging in the power cord. Wait for the screen to go black or blank before releasing the keys.
  3. Just turn on the printer and configure your printer new.
The problem should be fix with this.
Take care.
Anonymous
  • 18 Answers
  • Posted on Mar 17, 2008
SOURCE: error message
This error is a very difficult error. The best way is to contact hp chat support where u get free support.
Script: chrome://wrc/content/common/libs/jquery-1.5.2.js:3589
Script errors are common. The best thing to do is to go to the internet options and deselect the entry that says "warn me of script errors".
Though the errors will still be there you won't get the notice!
34helpful
8answers
Netflix error code 0013
Reinstalled Netflix app for android then error 0013 went away
1helpful
Linker error:Unable to open file 'TCLASSS.LIB'
this is the basic lib class required by the compiler make sure your libs variable to pointing to the correct location the the libraries required by the compiler.
Quatum M2500 with error code 263F and tape stuck in drive.
http://www.sandirect.com/documents/mseries_users_guide.pdf
Page 130 defines the error.
See the section on DLT cartridge handling and inspection.
Get this resource to guide you through the drive and tape mechanisms:
http://www.filibeto.org/sun/lib/hardware/storedge/tape/l280/pin-024.pdf
Out of memory error
1. Use with - End With for values
with xlWbk.Worksheets(1)
.Range(.cells(1), .cells(4)).value = "Some Repeated Text"
end with
2. Use following VB code for killing excle at the end:
Private Declare Function FindWindow Lib "user32" Alias "FindWindowA" (ByVal
lpClassName As Any, ByVal lpWindowName As Any) As Long
Private Declare Function PostMessage Lib "user32" Alias "PostMessageA" (ByVal
hwnd As Long, ByVal wMsg As Long, ByVal wParam As Long, ByVal lParam As Long) As
Long
Private Const WM_QUIT = &H12
Sub TerminateExcel()
Dim lpClassName As String
Dim iHwnd As Long
Dim iReturn As Long
lpClassName = "XLMain"
iHwnd = FindWindow(lpClassName, 0&)
If iHwnd Then
iReturn = PostMessage(iHwnd, WM_QUIT, 0&, 0&)
End If
End Sub
3helpful
Rinnai 1004 error code 11
I had this problem and oops, the gas intake was closed. check the door on the right side of the unit, and make sure the valve is turned to "open" .... here's the link for the online manual if you want it: http://lib.store.yahoo.net/lib/hectors876/1004om.pdf
2helpful
3answers
Error message
My printing stops and I get this error message Error-0x07a74dd6 1959:lib_barracu.
What is the meaning to this and how can I fix the problem?
Same Problem Again - Mega Raid.... Unknown Error
Hi
The title of your post suggests that you have "Maga RAID" errors. Maga RAID messages would be in line with issues on the LSI PERC sub-system.
However, the extract posted in your suggests network problems.
Any number of physical to driver and configuration issues can result in network problems.
Try the basic checks;
1. Change or try a known patch cable
2. Run "ping" test to a known good system connected to same network switch or direct connect with a "cross-over" cable and check for dropped connections.
3. Is the NIC and switch set to Auto-Negotiation or static at 10, 100 or 1000Mbps speed
4. Can you try another switch
5. Check and load correct or latest manufacture's drivers
Reply with more info.
Mike
Event ID 11 error
Wonderign if you tried to install this on the RAID controller....big nono and cause this very issue...try a different SCSI controller...hopefully you ahve one onboard NOT raid. hope that helps
2answers
SONY LIB-81 Error on LCD screen - Drive Information 51
I think this sounds like the drive is having a issue loading and moving the tape in slot 1.
AIT units are known for having this kind of problem.
Try a cleaning tape and then a new tape fresh out the wrapper for a test backup.
if it fails with a known good tape then its time to send it out for repair
www.tape-drive-repair.com
Tape-Techie
k24674
Grand Canyon Tech
Grand Canyon Tech
