Cannot open dooe with exterior door handle
You will have to remove the door panel. To do this use a phillips screwdriver and remove the two screws under the inside door handle. Then lift and remove the section. Remove another screw from the interior lower left corner. Pry the window crank apart "if exists" then use a T20 torq bit to remove the screw in handle. Remove the panel by lifting and pulling at same time. With window in up position you can see inside the hole a rod going from the door handle to a bracket with a Yellow clip. Slide the clip to the open position and pull the rod out of the clip. From the outside of door under the handle there are two rivets. Use a punch and knock out the center of each rivet. Then use a 1/4" drill bit and drill out the rivet. A flat tip screwdriver will be used to knock off the rest of the rivet. You will need two flat head screws and lock nuts or to reinstall the handle. Lift out old handle with attached rod. Twist rod as you pull to remove it and install it into the new handle. Place the rod through the hole and look inside to be sure is will move to the location of the yellow clip.Install the screws from the outside and the nuts from the inside and tighten. From inside connect the rod to the yellow clip. Lift on the rod while closing the clip. Then test door handle. If it doesn't work properly the rod was not lifted or pulled outward enough. Redo that step until you get it right. Reinstall inner panel as removed.
SOURCE: 1989 Exterior Door Handle for Ford Mustang
Once you pull the door panel you will see 2 nuts and a rod clip, that's all that holds it on.
SOURCE: door handle 1996 thunderbird
sounds like a plastic Sir clip of course you say external handel detached from door consider linkage clip has fallen down!
SOURCE: How to replace '96 Ford Explorer driver side exterior door handle
You will need to remove the door panel to gain access to the handle. Roll the window up or down as needed to get to the nuts that attach the handle to the door. You will also need to remove a rod the goes to the door lock. You will see the rod after the door panel is removed. Good luck.
SOURCE: Driver side exterior door handle pulls the locking
Take the door panel off the inside of the door. (Should involve screws at the bottom, plus bolts through the interior handle. Then pull out at the bottom, and lift upward Google for expedition door panel removal for more specifics if needed).
It sounds like the exterior handle linkage is binding against the lock button linkage. Actually looking in while pulling the handle would confirm. You then should be able to just bend the rods a bit to move them apart.
SOURCE: How do you open the door on a 2001 Ford Ranger if
You can go to a parts store and buy a slim jim. It's a flat metal bar that slides between the glass and the rubber on the door. Get a flashlight and use the tool to hook the linkege that the handle connects to inside the door. You will be able to open it like that. If you don't think you can handle it call a tow company and tell them you need a lock-out. They can get it opened for you for about $50 bucks.
