1995 Isuzu Rodeo Logo
Posted on Feb 26, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is oil pressure switch on 1995 oil pressure switch
raj somaiya
Level 3:
  • Isuzu Master 5,370 Answers
  • Posted on Mar 03, 2012
raj somaiya
Isuzu Master
Level 3:
Answers
5370
Questions
0
Helped
3570781
Points
14579
For oil pump,oil pump pressure,oil warning light,oil low,oil ewplacing and other car engine oil problems,the help links are provided below.Click the link to go through the procedure :-----Oil light came on and the car died?http://schematicsdiagram.blogspot.in/2012/03/oil-light-came-on-and-car-died.html--------How to replace Oil filler cap or breather cap?http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-oil-filler-cap-or.html---------Oil pouring out from left front of engine?http://schematicsdiagram.blogspot.com/2012/01/oil-pouring-out-from-left-front-of.html------Common Causes of Car Oil Leaks?http://schematicsdiagram.blogspot.com/2011/12/common-causes-of-car-oil-leaks.html--------Troubleshoot Car Oil leak?http://schematicsdiagram.blogspot.com/2011/12/troubleshoot-car-oil-leak.html--------Oil change details?http://repairhelpcenter.blogspot.com/2012/01/toyota-highlander-sport-oil-change.html---------Low oil pressure light?
http://howtobyme.blogspot.com/2011/11/low-oil-pressure-light-on-dodge-magnum.html
leaking oil from oil pan?
http://howtobyme.blogspot.com/2011/11/kia-sportage-leaking-oil-from-oil-pan.html ----------
Car Turns OFF due to low oil pressure warning light?
http://schematicsdiagram.blogspot.com/2011/12/car-turns-off-due-to-low-oil-pressure.html
leaking oil from timing cover?
http://technoanswers.blogspot.in/2012/02/toyota-corolla-leaking-oil-from-timing.html
For more oil and oil pump details check out the direct links below: ---
How to Replace Oil Pan on car?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-oil-pan-on-audi-a4-and.html
How to Replace an Oil Pan Gasket?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pan-gasket.html
HOW TO REPLACE AN OIL PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pump.html
HOW TO CHANGE ENGINE OIL AND FILTER
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-engine-oil-and-filter.html
HOW TO REPLACE AN OIL PRESSURE SWITCH (SENSOR)
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pressure-switch.html
How to Check Differential Oil Leaks and Replace Oil
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-differential-oil-leaks-and.html
HOW TO PERFORM A BASIC ENGINE TUNE UP-OIL CHANGE
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up-oil.html
Oil pan Gasket on car?
http://howtobyme.blogspot.com/2011/11/oil-pan-gasket-on-1998-toyota-tercel.html
Oil pressure for car?
http://schematicsdiagram.blogspot.com/2011/12/oil-pressure-for-2001-gmc-jimmy-v6.html
How to replace Oil Pan on car?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pan-on-2008-honda.html
How to replace Oil Pressure Sensor on car?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pressure-sensor-on.html
How to replace Oil Pump on car?
http://howtobyme.blogspot.com/2011/12/how-to-replace-oil-pump-on-2008-honda.html
Car oil leak?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leak.html
Car oil leaks from valve cover gasket?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leaks-from-valve-cover-gasket.html
Oil light blinks on dashboard?
http://schematicsdiagram.blogspot.com/2011/12/oil-light-blinks-on-dashboard.html
Oil pressure issues on car?
http://repairhelpcenter.blogspot.com/2012/01/oil-pressure-issuers-on-toyota-tundra.html
Oil leaks from air filter on ford?
http://technoanswers.blogspot.com/2012/01/oil-leaks-from-air-filter-on-ford.html
Wire running from oil pan to alternator?
http://technoanswers.blogspot.in/2012/02/wire-running-from-oil-pan-to-alternator.html
Why car leaks oil from oil filter?
http://schematicsdiagram.blogspot.in/2012/02/toyota-camry-leaks-oil-from-oil-filter.html
Why engine is consuming lots of oil?
http://schematicsdiagram.blogspot.in/2012/02/2008-scion-xb-24l-engine-is-consuming.html
Maint REQD message on car dash?
http://schematicsdiagram.blogspot.in/2012/02/maint-reqd-message-on-2008-lexus-rx350.html
Remove Sump oil pan?
http://repairhelpcenter.blogspot.in/2012/03/remove-volkswagen-sump-oil-pan.html
Sump not coming OFF?
http://repairhelpcenter.blogspot.in/2012/03/sump-not-coming-off.html
How to remove the sump on car?http://repairhelpcenter.blogspot.in/2012/03/how-to-remove-sump-on-vw-beetle.html----------Car oil sump removal diagram?
http://repairhelpcenter.blogspot.in/2012/03/volkswagen-beetle-oil-sump-removal.html
This will help.
Thanks.
1helpful
My oil light stays on even though I have enough oil in my
The oil warning light is telling you the oil pressure is below 10psi.
If the pressure switch is working correctly the engine has lost oil pressure and-or oil.
You would need to replace the switch or have the pressure checked with a mechanical gauge.
Where is the oil sending unit on a 1995 Buick Skylark 3.1 V6?
OIL PRESSURE SWITCH
1995 Buick Skylark 2.3L MFI DOHC Quad 4 4cyl
The Oil Pressure Switch is located:
OIL PRESSURE SWITCH
1995 Buick Skylark 3.1L SFI OHV 6cyl
The Oil Pressure Switch is located: Under hood, center, front engine area, front driver side of engine, mounted in engine block
Oil leek above the oil filter
http://www.autozone.com/autozone/parts/1995-Honda-Accord/Oil-Pressure-Switch/_/N-j1i0dZ8znc6?filterByKeyWord=oil+pressure+switch&fromString=search,Above the filter,theres the oil pressure switch,click on to link to see part,to remove,disconnect electrical connector,get wrench and unscrew,turn conterclockwise.
1995 jeep cherokee sport 4.0L. Oil gauge keeps sending false message ie. jumps from almost center past the highest point on the gauge. How do I fix this problem? where is the gauge sender located?
OIL PRESSURE SWITCH-I'm not sure if this is the gauge sender, though. 1995 Jeep Grand Cherokee 4WD 4.0L MFI 6cyl The Oil Pressure Switch is located: Under hood, passenger side, lower engine area, above oil pan, mounted in engine block.
Oil level light comes on inthe afternoon on 1995 cadillac 4.9 when coming to astop
assuming your oil is full and you have changed the oil regularly the light is telling you you have low oil pressure
untreated this will lead to engine failure
if you are lucky, its just an oil pressure switch issue
that being said... check you oil level and/or change your oil and see what happens
1helpful
2answers
I have a 1995 Chevy Lumina with the ''Low Oil'' light on.
may be the oil sending unit is bad
may be the oil pump
is there any noise in the engine?
have the oil pressure check at a repair shop to make sure you have enough oil pressure
if it's ok then have the shop replace the switch while they have the old one out to check the pressure
2helpful
2answers
Oil pressure light keeps coming on
Check the oil level is not low, and the oil in use is of suitable grade & quality.
If it only comes on at idle, you may have a faulty oil pressure alarm sensor switch.
Either replace it, or preferably, get the engine oil pressure tested using an independant oil pressure gauge.
If it is verified that the oil pressure is indeed low, you may have to look further for other engine problems, such as worn camshaft/crankshaft bearings.
1helpful
2answers
Low oil pressure light is on
Until u have a mechanical test gauge hooked up to verify the oil pressure is ok assume it is not a good idea to drive, low oil press will destroy a $4000.00 engine very quickly.
1helpful
Oil light comes on - 1995 achieva
Hello theusbaker: The oil pressure switch is located at the left front of cylinder block .Near the knock sensor. The oil pressure level sensor is located in the oil pan. Should you need further help please just ask. Please rate this information as it does help in feedback. Thank You for using FixYa. Roger
Gauges say no pressure in engine 1995 vw golf
There are two pressure switches. One for oil pressure and one for a dirty oil filter. Are you sure you've changed the right switch. If car drives for 30 mls it doesn't sound like you need an engine. The spluttering is likely to be completely unrelated to the oil warning I suspect.
Cheers John
Top Isuzu Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you an Isuzu Expert? Answer questions, earn points and help others
