Question about Altec Lansing Stereo Headset with Microphone Headset
Skype not working
No one can hear me thru headset
    President:
  • 1,952 Answers
Mic low sensativity problem.here is a "microphone boost" checkbox under realtek sound manager program ->mixer tab->playback-> (scroll to right) and you see mic volume.
Here is the very sneak part. There is a speaker icon and there is a button with ".." written on it. Press that and it shows the "microphone boost" checkbox.
Posted on Oct 29, 2008
  • mohammed marika thambi
    mohammed marika thambi Oct 29, 2008
    use this link
    ... http://forum.skype.com/index.php?showtopic=13336
    First, make sure you are using the most recent version of Skype as we are continually improving quality in each version.
    Make sure all your PC's drivers are up-to-date (sound, video,
    motherboard controllers etc - please contact the manufacturers of your
    hardware for updated drivers).
    Also make sure your firewall/router is not blocking Skype in any way.
    Try opening UDP traffic both ways to both the port found in Skype's
    "Connection" window in Tools -> Options and also ports 80 & 443
    - tick the option to use the ports and open both TCP and UDP traffic to
    all three - keep in mind UDP traffic's availability for Skype results
    in better sound quality than just data traversal over TCP. If you're
    not sure how to make such changes ask a tech-savvier friend or your
    system administrator for assistance.
    Another way of improving quality is to shut down any file sharing
    applications or internet software that consumes a lot of bandwidth. If
    you are downloading files at the same as using Skype call quality will
    be greatly diminished.
    Also a manual refresh in Skype's data traversal information can be helpful:
    The procedure is as follows:
    * Close Skype
    * Locate the shared.xml file found in
    C:\Documents and settings\Your Windows Username\Application data\Skype\shared.xml
    (showing hidden folders and files has to be turned on)
    * Delete shared.xml
    * Start Skype (shared.xml will be recreated).
    Another possibility to improve conditions is to disable QoS (Quality of Service) packet scheduling.
    Go to Start -> Control Panel -> Network Connections
    Right click on the connection you are using (e.g. "Local Area Connection") and select Properties
    Untick the "QoS Packet Scheduler"
    Genius:
  • 1,011 Answers
Sir,
Click this link for more information........
http://support.skype.com/index.php?_a=knowledgebase&_j=questiondetails&_i=35
Also Check........
On a PC with external speakers and also a headset with microphone. Windows XP is configured so that standard audio are external speakers and standard microphone is the headset. Skype is configured to use the headset for audio in and out.
This way one can listen to sound from the PC and from MP3 players through external speakers and if there is a call to make or take, this is going through the headset.
But now there is the problem that the noise level for the headset is too low. Increasing volume has no effect on the headset, it only affects the external speaker's volume.
Now the solution: Going to the control panel and opening the sound setting, go to the audio tab. The external speakers are selected as default. Just temporarily select the headset and then click on volume just below. You can now set the volume for the headset, click OK and click cancel (!!!) on the sound control dialog box. This way the external speakers remain as default output.
Skype-->Tools -> Options -->Sound Devices-->audio device/USB/etc Audio Device (do NOT use windows default device)
You can also tick the ring pc speaker check box as this is a good backup to alert you even
if the main speakers are off or turned down.
Windows:
Start-->Control panel-->Sound and Audio devices
On the audio tab set the default playback device to your main soundcard(AC97/Audio-chip/add-on-adapter), etc.
Your installed audio device must be present there.
If not, reinstall audio device
thanks
good luck
    Sergeant:
  • 213 Answers
This is what you want just click on it its a official website
http://support.skype.com/index.php?_a=knowledgebase&_j=questiondetails&_i=147
1. Audio settings all versions
For Windows Sounds & Audio Devices Properties:
Audio > Sound Playback: Your on board sound/Sound Card.
Audio > Sound Recording: Your on board sound/Sound Card.
Voice > Sound Playback: Your on board sound/Sound Card.
Voice > Sound Recording: Your on board sound/Sound Card.
For Skype Sound Devices:
Audio In: Your headset/mic or USB device or Web cam mic.
Audio Out: Your headset/mic or USB device.
Ringing: VoIPVoice USB Phone or on board sound/Sound Card also tick Ring PC speaker.
2)Check if your micro (pink) and speaker (lime) jacks are really correct and fully inserted!
They sometimes stuck.
For test only you can use earphone instead of microphone for Line In.
Standard micro in Line In will NOT work.
Go to:
Start
Programs
Accessories
Entertainment or go to
Volume Control; right click on loudspeaker icon in Task Tray
Options
Microphone
Scroll down
Check "Microphone"
If the bar "Microphone" is available, the microphone is detected by Windows now go on
(If not, Windows has a problem with your microphone)
Just to check if your microphone is broken or bad, you can use your headphones instead. They really work!
Which one L or R is microphone now, I think it's L
Check "Advanced properties"
Check Micro "Advanced"
Open
Check "20db boost" or "1.MIC boost" depending on language version
Volume level can be left in any position.
Mute microphone!!!
3. Check audio now on windows base.
Start
Programs
Accessories
Entertainment
Soundrecorder
4. Once done, test with Skype Test Call echo123.
  • shivam raj
    shivam raj Oct 29, 2008
    just copy the link and
    you will find what you want its a minor mistake nothing to worry
    thanks for using fixya
    golu_fixya
  • shivam raj
    shivam raj Nov 01, 2008
3 Suggested Answers
SOURCE:
SOURCE: Using Logitech headset & enable Skype to ring via Desktop speakers
I am having the same problem. Can anyone help?
Posted on Jan 24, 2008
  • 118 Answers
SOURCE: Clear chat mic doent work
in skype go to tools>options>audio setting make sue the microphone is logitech and the green bars should start moving as you talk.
if no logitech appears or the mic is not producing sound. call logitech for warranty info. if the mic is producing sound below is "make a free skype test call" to see if the program is transmitting.
Posted on Jul 18, 2009
Skype microphone does not work
You need to check your audio (sometimes called Sound on some systems) settings (under control panel on Windows or Settings on Mac).
Under input (or sometimes called sound recording), make sure the headset you are using is selected.
You might also try using the headset with another program to see if it will record your voice. (Audacity is free http://audacity.sourceforge.net/. You can download it and try recording on it.)
If it still doesn't work, here is a page on Skype that has a Microsoft tool you can try - https://support.skype.com/en/faq/FA897/why-can-t-the-other-person-hear-me
Here is the link for Mac sound troubleshooting on Skype - https://support.skype.com/en/faq/FA10885/why-can-t-my-friend-hear-me-on-skype-for-mac-os-x
Feb 24, 2013 | Samsung Computers & Internet
Doesn't work with Skype
Fixed it: the microphone on the headphone was switched off - it's a bit of a design weakness in the Logitech headset: it's easy to unintentionally turn the microphone off while putting the headset on. The lower half of the right headphone's central medallion is a button - indicated by a crossed out microphone icon.
Dec 25, 2009 | Logitech ClearChat Pro USB Headset
Jul 18, 2009 | Logitech ClearChat Stereo Headset Headset
Cannot hear Skye ringing thru headset otherwise sound is good
try to re install again the skype software on your unit.
Jun 26, 2009 | Plantronics Radio Communications
Hearing through the PC microphones instead of the headset
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Jan 04, 2009 | Logitech QuickCam Express Web Camera
Skype does not recognize my Microphone
not all headsets are compatible with Skype. You should be able to check online on their website as to whether or not that particular set you have is compatible.
Dec 24, 2017 | Computers & Internet
Logitech Microphone Not working
Hi, I have a skype approved logitech headset. I can hear sound, but I cannot record sound or communicate on it. I cannot even find the headset as option as Preffered Device in Sound and Multimedia. I am using Windowsxp
z. Please help.
Feb 21, 2008 | Logitech (980174) Headset
Altec Lansing Stereo Headset with Microphone Headset Logo
479 people viewed this question
Top Altec Lansing Radio Communications Experts
Michial Gueffroy
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Jose Ma DM.
Jose Ma DM.
Are you an Altec Lansing Radio Communication Expert? Answer questions, earn points and help others
