Genset will not increase rpm when put under load ,what part should I look at to rectify the problem.
SOURCE: RPM/voltage fluctuation on Guardian Primepact 50G
The voltage regulator board on this unit is notorious for failing. If you are handy, you can replace it yourself with basic tools and a voltmeter to set the output. The part is about 200 dollars. Good luck
