I bought a used Juki DDL5550-N 7 I have the instruction manual but it doesn't show how to check for oil. Can someone help me. Thanks
Hi there,regarding after what you can change oil, you can change oil after 8 month.regarding how can you change the oil, please check screw at the right side on the oil pan, remove it and but something under the oil pan to empty the old oil.when you re full oil pan again please check there's tow mark high and low you must make oil is equal with high level.best regards
SOURCE: I have a brand new
Hi and welcome to FixYa, I am Kelly.
This is a self-oiling industrial sewing machine that uses a reservior in the bottom of the unit for lubrication. There is a sight gage on the lower left side of the unit in the base that once filled with oil you will see the oil splashing as the machine operates. Since this is a new machine you fill the lower reservoir to the High mark on the sight gage and then operate it a 3000 Rpm for 10 minutes to do the initial self lubrication. Instructions are in section 6 of the users manual. The main unit is tilted on the base to service the oil in the lower reservior. They don't bother telling you that once the unit base is installed in the sewing console that you should then fill it with oil before installing the main unit on the base.
This link should download your users manual so you can read it on the computer. See page 3:
http://www.google.com/url?q=http://www.juki.co.jp/industrial_j/download_j/manual_j/DDL8700/menu/pdf/instruction_eg.pdf&sa=U&ei=RP1KTqK8A6rkmAXgp9HvBw&ved=0CDUQFjAI&sig2=Tnu57Jl3GxY6Poevdo2WMg&usg=AFQjCNFzkTRDDqdrUjtV3b4zB91m43W8bg
Thanks for choosing FixYa,
Kelly
SOURCE: Looking for JUKI MOR-816 Instruction Manual
http://www.raichert.com/adobe/MO804-12-16%20Inst.pdf
SOURCE: I have Juki ddl5550 model cs-4002-6 that the
It might be your connections inside, Juki is a great mechine I would fix it.
call 303 770 6321
AAAA TEVA
Hi Kelly it's actually a used Juki DDL5550N-7 so I don't now how much oil is left in the reservoir. My apology I should not have said Oil my Juki. I meant how do I replace the oil. There is a oil sight window to the top right of the Juki machine, which I don't know how to determine if it needs oil.
How do I lift the machine to get to the oil pan reservoir. Do I have to disassemble anything? This is what I cannot find in the manual.
Thanks
