Microsoft Xbox 360 Console Logo
A
Anonymous Posted on Feb 26, 2012
Www.xbox360.com/ipaddress-help ip setting,ip address,subnet mask
4 Related Answers
Anonymous
  • 470 Answers
  • Posted on Nov 15, 2008
SOURCE: how do I get online?
onlie?? what is your unit it is a computer????
shaun taylor
  • 1527 Answers
  • Posted on Sep 19, 2009
SOURCE: ip address,subnet mask, gateway
168.192.1.1
shaun
Anonymous
  • 340 Answers
  • Posted on Feb 15, 2010
SOURCE: what is an ip address
Remember to thumbs up this solution if it helps, if not comment me for further advice.
This ip address is basically what your internet service provider (isp) allocates for your modem, this is where you can find all the information you need using vista.
On your computer, click start.
click on network
in the blue tab across the top click on network and sharing center
next to conection, click on view status
click on details, this will give you all the numbers you need to know.
Anonymous
  • 166 Answers
  • Posted on Dec 06, 2010
SOURCE: Can't find IP address, subnet
call to customer service for xbox, you can get number in net.....................
download repair guide to get your working procedure.........
CLICK HERE..................
TP-LINK N600
Your question is hard to follow. "got an X as it failed" what is it ?
What are the lease ip addresses from the DHCP server and what is the subnet mask ?
What is the default gateway in the DHCP lease ?
What is the router's internal IP address and subnet mask ?
What is the ip address and subnet mask of the computers used ?
What is the operating system used on computers
can you ping the router from computers ?
can you tracert www.google.com
from the dos prompt for ping (routers ip address)
what route does tracert reveal
does it get to the router
does it find the dns server ?
3answers
Cisco router 1841 connected to serial interface
Make sure you set up correctly the subnet mask.
tip
How to figure out your default subnet mask
A subnet mask is a 32-bit binary number, very similar to an IP address. And like an IP address, the subnet mask is usually expressed as a set of four octets written in decimal form, with each octet separated by a period.
The subnet mask is used by routers and switches to determine which part of a computer or other device's IP address is the network identifier, and which part is the host identifier. There are three default subnet masks, one for each of the IP classes A, B, or C. The default subnet masks are:
Class A = 255.0.0.0
Class B = 255.255.0.0
Class C = 255.255.255.0
To determine the default subnet mask for your network, all you need to do is see which class your network falls into. A network's class is assigned based on the first octet (the set of digits before the first period) of the IP address. For example, to find out which class the network 123.22.8.0 belongs to, you would see where "123" fits into the following table:
First Octet: Class:
1-126 = Class A
128-191 = Class B
192-223 = Class C
So for the example above, 123.22.8.0 is a Class A network, which means it would have a default subnet mask of 255.0.0.0.
Most home and office networks will be Class C networks, so your default subnet mask will typically be (you guessed it) 255.255.255.0. Not all networks use the default subnets, but for those that do, figuring it out is easy once you know which class your network fits into.
on Jun 23, 2010 • Computers & Internet
I need gateway address, subnet mask and TCP/IP Address for canon irc2620n
IP Address: 245.36.4.25
Subnet Mask: 255.255.0.0
Gateway: 245.36.0.1
If fail suggest to set iRC2620N to DHCP so that your DHCP server or router to assign a TCP/IP address.
http://www.usa.canon.com/cusa/support/office/color_imagerunner_copiers/color_imagerunner_c2620_c3200_c3220/color_imagerunner_c2620_c3220
I'm using two Macintosh Computers. I followed the quick setup wizard, all the right lights are lit. I've reset my broadband modem, I've reset the Dynex Router. Yet I can't make contact...
Richard have you tried setting up static ip addresses on the MACs
If you have other p.c's on network with auto ip assignment then alter the DHCP server lease to 192.168.1.10 to 192.168.1.240
then make ip address static 192.168.1.241 subnet mask 255.255.255.0 default gateway 192.168.1.1 and on the other mac
make ip address static 192.168.1.242 subnet mask 255.255.255.0 default gateway 192.168.1.1
http://www.macinstruct.com/node/550
EOC 2611P. I follwed the instruction to configure the antenna and when it come tthe time when i typed 192.168.1.1, i don't get the log in box for the antenna. I've been trying many time and i am jammed...
In order to log into this device, you must first configure the TCP/IP settings of your PC/Notebook.
1. In the control panel, double click Network Connections and then double click on the connection
of your Network Interface Card (NIC).
2. Select Internet Protocol (TCP/IP) and then click on the Properties button. This will allow you to
3. Select Use the following IP Address radio button and then enter the IP address and subnet mask.
Ensure that the IP address and subnet mask are on the same subnet as the device.
For Example:
PC IP address: 192.168.1.10
PC subnet mask: 255.255.255.0
4. Click on the OK button to close this window, and once again to close LAN properties window.
Login username and password are both admin for this device
All info on this device can be found here http://www.engeniustech.com/resources/EOC2611P%20User%20Manual%20v1.0.pdf
2answers
I need to know my ip adress and all that stuff?? help please
Inorder to find the ipaddress of your computer follow these steps,
1. Click on start? Go to All programs? Accessories?Command Prompt
2. You will find a black screen which is the Command prompt
3. In the command prompt you will find a blinking cursor , there you type in "ipconfig/all" (without cotes)and hit enter.
4. You will find ipaddress, subnet mask, default gateway , mac address/physical address and all other information of your comp.
Thanks in Advance!
With Regards,
Prema
Hi. i cant connect to print server d-link dp301p+ IP to configure it?! who knows what IP by default it have? 192.168.0.10 doesnt work... Thanks, Mike
First find out the IP address , Subnet mask,and Gateway addresses of your ISP ( Internet Service Provider ). According to above addresses, you have to complete the network settings of your printer by mentioning the different IP address .
To find out the above mentioned addresses, first open the control panel -> network connections -> local area connction -> properties -> Internet Protocol Version 4(TCP/IPV4) OR Internet Protocol Version 6 (TCP/IPV6)according to your ISP -> Properties
By the systematic selection as mentioned above you will get the IP address, subnet mask and Gateway addresses.
Suppose your IP address is 192.168.0.10 , the gateway may be 192.168.0.1 Or any number. And the subnet mask may be XYY.XYY.XYY.0.
According to your ISP addresses you have to complete the network settings of your printer. First press the additional functions -> system settings -> network settings -> TCP/IP settings -> fill up the addresses as follows.
IP address : 192.168.0.16 OR any number .
subnet mask : XYY.XYY.XYY.0.
Gateway : 192.168.0.1
Hurray ! the problem about your network connection with the printer to your computer will be automatically solved.
I cant log into my router even though I am using the 192.168.1.1 subnet mask
Go to run type in cmd a dos prompt will appear.
type in ipconfig /all and check your ip address. Chances are your ip address is 169.x.x.x which is an internal ipaddress. You will need to manually assign an ip address To do this go to my network click on view connections right mouse click the lan icon then go to the tcp/ip config and manually assign your ip address.
It needs to be the same subnet as your router so use 192.168.1.xx anything but 1 then you should be fine.
good luck
2answers
Adding additional computer problem
Yes, the xp machine connects to the net. DHCP is not enabled. The ipconfig/all command brings up the correct static ip address, subnet mask, and default gateway. But it does also say under the ip configuration that ip routing is not enabled. I did have the 2000 machine connected when I first set up the router yesterday, but I booted up my laptop to try to set up a wireless connection, and then I had to reinstall the entire router set-up.
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
