HP Officejet Pro L7680 All-In-One Printer Logo
Des Willson Posted on Oct 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printing mirror image/print
I adjusted some settings and now for some reason my print is mirrored (I am assuming it is for the transparent sheets for projector). I can't figure out what setting it is.
  • susans805 Dec 14, 2008
    printing mirror image
  • PLAVAN Dec 26, 2008
    i have tried the mirror image off and still not wokring
Martin Smallridge
Level 3:
  • HP Master 419 Answers
  • Posted on Feb 14, 2009
Martin Smallridge
HP Master
Level 3:
Answers
419
Questions
0
Helped
289609
Points
1120
Solution posted on this problem thread:
http://www.fixya.com/support/t1641997-mirror_image_printing
Anonymous
Level 2:
Novelist:
  • Expert 180 Answers
  • Posted on Oct 29, 2008
Anonymous
Expert
Level 2:
Novelist:
Answers
180
Questions
0
Helped
66505
Points
441
Go to control panel and go to printers or printers and faxes. If you see the printer icon right click on the printer icon and select printing preferences. Under printing preferences click on advance and look for mirror image. Click on mirror image and chage it to off
1helpful
I have a HP Officejet Pro L7680 All-in-One It appears to print the text in a reverse mode (just like Koranic Text). What should I do for the text to come out normal (readable)?
The image is mirrored in the printer options. Find the check mark next to "Mirrored" and uncheck it.
On the same tab of the driver you have also "Inverted" option.
Both options are usuable for press release. Mirrored images are printed on transparancy and used for preparing the drums of the typographic machines. The Inverted image is for preparing photopolymer stamps.
1helpful
3answers
PRINTING BACKWARDS
Go to Start>>Control Panel>>>Printers.
Select Printing preferences.
Go to Advance Tab.
Select Mirror images and turn it off or uncheck it.
Press Apply and OK to Apply the settings.
Also perform the same steps on Solution Center.
Open HP Solution Center.
Go to Settings>>Print Settings>>Advance Tab.
Mirror images=OFF
Print mirror image gel printer GX700
The mirror image setting is in the printer properties/ printing preferences. You can either go to control panel/printers/properties, or when you press print, and the window pops up, in printing preferences you can choose the mirror image setting.
1helpful
I want to print on transparency film; can't find it as an option
Go to the printing preference in your software driver and to the right you should see a "media type" radio button.Look through your choices and you should see a category for tranparencies.
Also make sure the the box under the media type shows auto sheet feeder.
Printer is printing job as a mirror image
I would have said Gotta be setting in your print dialogue box, but if the test page comes out as mirror image, must be
a setting on printer control somewhere
3helpful
go into the properties setting for the printer, go to advanced tab, then to the prinint defaults button on that tab. When you click on that - if you go to the advanced tab within there, you will see "mirror image" and i bet it says "ON" - click on the word mirror and it opens up the ability to set this back to off. Hope that helps!
All of a sudden my spread sheet is being printed as a mirror image.
The next time you go to print something, select "Preferences" when the first window opens. On the Advanced tab, under Printer Features look for "Mirror Image". Make sure it is set to "Off". If not click "On" and change the drop down to "Off".
HP L7590
I hit print on the pdf file, went to properties and THAT was still set to mirror, so I changed it and everything was o.k.
Mirror Image Printing
Need to use editing software ie photoshop etc
k24674
Grand Canyon Tech
Grand Canyon Tech
