SOURCE: graphing trig functions
Put the calculator in radian mode and it will graph trig functions just fine. If you don't know how to change it to radians, then go to mode and cursor over to select radians. I am assuming you know where the sine, cosine, tangent, etc. keys are.
SOURCE: ti 84 plus problem
The calculator only displays from -10 to 10 on the x and y axes, and both of your lines are outside of that range. However, it is easy to change that.
1. Hit the gray "WINDOW" button that is directly under the screen
2. Change "Xmax" to 150
3. Change "Ymax" to 200
Remember to change both of those values back to 10 when you are done with this problem!
Here's how to graph it:
1. Hit the "Y=" button
2. Enter your first equation after Y1, and your second equation after Y2
3. Look over both the equations to make sure you typed them correctly
4. Hit the "GRAPH" button
5. If you don't see the intersection you will need to adjust Xmax and Ymax again
6. Hit Hit "2ND" and the "TRACE" to bring up the "CALC" menu
7. Scroll down to "intersect" and hit enter
8. Hit enter 3 times (You use the first and second curve options when you have more than 2 lines)
9. It should display the coordinates at the bottom
10. I got (76, 142.1) for the intersection
Thanks for asking this question! I used to do this a much harder way, but while I was calculating the answer to your question I hit a wrong button and accidentally found this method!
SOURCE: My TI--84 plus calculator won't display the 7
Use the [Y=] entry screen to enter the functions you want to graph. Make sure that the = sign after Y1, Y2 etc. is highlighted (black). If the = sign is not highlighted the corresponding function will not be drawn. You can can up to 10 functions, but what is the point of drawing so many if they overlap?
Anyway, to change the graph style of the curve for a particular function, use arrows to move to the line, then use left arrow to the bit of line that appears to the left of the Y. Highlight the segment an press ENTER. Each time you press ENTER the style changes to another one. Beware of the unconnected bubble style. During the drawing it will show the position of the point being drawn, but at the end, the whole curve, so to speak, evaporates.
As to simultaneous graphs, if it is important to you to have the graphs drawn for all the curves at the same time, you can enforce that by pressing [MODE], and using down arrow to reach the 6th line Sequential Simul. Use the right arrow to highlight Simul and press ENTER.
Whether drawn sequentially or simultaneously, all graphs will be displayed, except for the ones with the unconnected bubble as style.
Hope it helps.
SOURCE: TI-84 Plus LCD display broken. Is replacement available?
Contact [email protected] or www.ti.com/calc .
Hope it helps
SOURCE: TI 84 plus calculator refuses to graph more than one function
Please, read the following, even if you already know some of its contents.
You should make it a habit to clear the RAM every time you start a new type of problem.
Hope it helps.
