My phone time is continually 5 minutes behind the world clock and the clocks and phones I see. HELP! I have tried turning it off/on - Have taken out the battery - done a complete reboot. Nothing fixes.
SOURCE: my clock has shrunk on my HTC Touch Pro
The onlu thing I can think of is manually going to the settings, go to system, scrool down to remove programs, and click on the file name of the download and removing it that woay. THat should work and if it doesnt, take it to ur comapny wtore. They will most likely give u another one for free because they are lazy.
SOURCE: My HTC Hero brought up
Resetting the phone deletes
all data, including downloaded applications, and resets the phone back
to its initial state. Press HOME > MENU, then tap Settings >
Security > Factory data reset. On the Factory data reset screen, tap
Reset phone and then tap Erase everything. To reset the phone using
phone buttons, with the phone turned off, press and hold the HOME, END
CALL/POWER, and BACK buttons. The reset process will start after a few
seconds
SOURCE: phone turns off all the time and gets hot did a
Does this phone have a WIFI connection? If it does, check to be sure that it's not constantly on.
In fact, turn off your bluetooth, WIFI, GPS, and any other unecessary items.
This will save your battery and prevent drain.
If that doesn't work, You may need to get a replacement phone through your carrier's warranty program.
SOURCE: my htc surround (windows 7
PLease do a hard reset on the phone and here is how you do it
1. Turn the phone off. If it's frozen or unresponsive, pull then replace the battery.
2. Press and hold the Volume Up and Volume Down buttons and power the phone back on.
3. Continue to hold Volume Up and Volume Down until a factory reset screen appears.
