After relocating washer, it will no longer fill with water.
SOURCE: The washer is saying F20
Check to be sure that the drain hose curves up higher than the washer tub. If that does not help, check to sure the unit is level...next turn the washer off, unplug the washer for a few minutes , then replug it into the wall outlet.Be sure that you are standing in a dry area and that your hands are dry. This may reset the operating system. If it has water in in after this, try the drain and spin cycle, and then try a regular quick cycle to see if it works.
Good luck to you, and if this does not work, get back to us.If your problem is solved please let us know by rating this answer. Thank you for using FixYa.
