I have the same problem, my dock was broken, but I got round it instantly by plugging my ipod into the speaker via the headphone port on the ipod and into the audio in port on the speaker. When new, the speaker actually came with a spare lead as you can plug any mp3 player into it this way. The sound quality seems exactly the same and I dont have to throw away the speakers. If you have lost the lead you need a 3.5 mm male to male headphone lead, just pence in any electrical shop or amazon.
SOURCE: how to open the jbl radial micro speaker set?
Bit late! Just remove the four rubber feet underneath (self adhesive). Take out the four philips screws. It's a bit of a mess inside - you'll have to remove the connectors and some screws to get to the i-pod connector. You dont need to remove the button pcbs just the main board. The i-pod connector pcb is on the end of the grey ribbon cable connected to the main board (the button end of the unit).
SOURCE: JBL Radial Remote stopped working.New battery replaced no avail.
Turn on the JBL with the ipod in place, turn off at the mains plug, turn back on, turn on your JBL and the remote should work.
SOURCE: ipod adapter clear
Sorry, it 'WILL NOT' charge a 4G Nano on this Dock no matter which adapter you use!!
Clear Adapters have small numbers on them which relate to different iPods - A reference sheet relating to these numbers is enclosed with the Adapter Pack!
SOURCE: my jbl radial, when using a 120 gig ipod, will skip songs.
Not a solution but mine sometimes causes my ipod to skip mid-song to the next song or podcast as well. JBL customer service is usually good and I've been meaning to check with them since I finally figured out it's the radial and not my ipod.
