My kenmore electric dryer quit working mid cycle and just stopped
My Kenmore electric dyer quit working mid cycle and now it wont start. My uncle checked the thermo couple fuse (?) and said it was ok (he had a meter?)
Just stopped midcycle and will not start back up, it is not the circuit breaker or plug.
AnonymousMar 17, 2014
What would cause a Kenmore KE3 dryer to cut off mid cycle.What would cause a Kenmore KE3 dryer to cut off mid cycle.
AnonymousMar 25, 2014
stopped working mid cycle and now it won't work at all and it's only 5 years oldstopped working mid cycle and now it won't work at all and it's only 5 years old
You can't post conmments that contain an email address.
It is probably the heat sensor, it turns off the machine if it gets too hot. You will most likely have to replace this or bypass it. It should show you where it is in the manual or the electrical schematic that comes with the washer
I have a kenmore gas dyer, it will start to dry then go out and just run. you can shunt it dwn resit the timer the time it needs start it and it will lite for a cycle then go out, short burn, then out. is it a senor???? JW
sounds like the timer, unless it has a Evenheat contol board and a seperate motor relay, in which case its most likely the relay, or could be the computer
