Question about Sony DDS SDT-9000 DAT Tape Drive
Sony DDS SDT 9000
XP drivers for the tape drive?
    Problem Solver:
  • 6 Answers
6ya staff
SOURCE:
Ive just bought an old sony dat drive SDT-5000 and want to use the external housing frome one I already have. Does anyone know how to set the jumpers? I can supply an image of this if it helps
supply an image (and would be great if you could supply image from old broken one and new one)
I'm a bit confused though: if you have an internal working sdt-5000 that you want to put into an external broken sdt-5000, it should be as simple as getting the enclosure open, then swapping the internal drives; i.e. external enclosures usually still use the same spec internal drive so it would just be an ide or scsi connector cable.
I’m happy to assist further over the phone at https://www.6ya.com/expert/shunter_ccf54e0913bd0501
Jul 12, 2016 | Sony DDS SDT-5000 DAT Tape Drive
Stable lift jacks
I think you need to review this - I thik you have trouble if you are trying a 30 amp cord into a 4mm DDS DAT Tape.
Dec 05, 2013 | Maxell Products - 1/8 DDS-1 Cartridge 90m...
How to use the superstation 10gb with XP? Can you use this tape backup with XP?
Sony does not support this configuration, the last OS they supported for this is Win 98. It is doubtful that any of the generic drivers that come with XP will work with the drive.
Jan 07, 2011 | Sony SuperStation QIC Tape Drive
Tar /dev/st0 can't write: error
Sounds like your tape drive or possibly the tape you are using is faulty.
check the following:
#1 - use a different tape
#2 - check that the read-only is not enabled on the tape(s)
#3 - run diagnostics on the drive (if it's come with software for diagnostics).
#4 - return it to the supplier to test and replace if under warranty.
Apr 04, 2010 | Sony DDS SDT-S9000 DAT Tape Drive
DDS-5 not compatible with windows 2008
I am pretty sure that the driver should be compatible with win08.
If you are using backup exec then try switching to use symantec drivers for your tape drive (setting withing BUEX)
If it is just the tape that cant be read or identified and was backed up using windows backup then try restoring the backup on a 2003 server and then copying the data across the network.
May 10, 2009 | HP 364446-001 Storageworks DAT 72x6 DDS-5...
Unlocked tapes recognized as locked
this is probably due to a stuck microswitch in the tape drive unit as the locked tag presses a microswitch when loaded it is possibly these microswitches that are failing, as one of the switches detects if a tape is loaded and the other detects is a tape is locked, so problems with these switches would mean that it cannot detect if the tape is loaded properly.
Sep 30, 2008 | Sony DDS SDT-D11000/ME DAT Tape Drive
Tape Backups
i cannot access the tape media but the engine shows that its running properly whats the problem
May 28, 2008 | Quantum (BH2BA-YF) (BH2BAYF) DAT Tape...
Open Questions:
Aol verizon Tech support number O#1=855=536=5666 Aol verizon Customer Support- FBVVELJ Aol verizon is one of the biggest companies in the world which is providing its services. It has invested in various functions and can provide the best when we compare to others. So if you are interested in having the services, then you should not think twice. As they even offer you the benefit of having the help from the Aol verizon email Toll free Number. Once the person has those, then the user will be able to get the help from the user in a way which is going to make his experience a euphoric one. So dial the number whenever you are facing the problem. Aol verizon support number When you are using the Aol verizon for the cable, telecommunication, internet services or anything, then you will find it to be the best. The user will find that there is no other option when it comes to the quality of the services they provide. But even after that, there are some problems which are needed to be tackled. For that, the user can dial the Aol verizon support number and ask for the help. Once you dial the Aol verizon customer support number, you come in contact with a team of experts at the Aol verizon customer service. They will be able to help out the user with any situation in which they are stuck. So whenever the user feels that he or she is stuck, then there is no need to make any rash decisions. As the team on the Aol verizon support phone number will help you with that simply and quickly. This is Aol verizon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Aol verizon agent. Features of Aol verizon support number A person can face difficulty while using technology anywhere and anytime. But this does not mean that you will leave that application or make any rash decisions. As you or any user will be able to get the help from the Aol verizon customer support phone number. Here are some of the features of customer service: The Aol verizon customer support phone number which you will be using to contact them is available 24/7. So the user will be able to get the help whenever they are facing the problem. There is no need for the user to find the solution his or her own and waste time. AS the Aol verizon customer service will be doing all that for you. The only thing that will be required from you is to dial the number and apply the solution provided by them. When you want the help for the service for which you have paid, then you do not want to spend any more money. For this Aol verizon provides you the facility of Aol verizon support phone number. The number which you or user will be using is toll-free. So they will be able to get help from an expert without paying any money. There is no waiting time for the call the customer is making for the help. So the only time that you have to wait to get in touch for the help is a few seconds. And after that, you will be able to get the help that you want. Problem Faced Various problems can be face by the user while using the Aol verizon. Here are some of the issues that you are going to face when you are using the application: The user might be having trouble with the connectivity of the internet services. There might be questions regarding the plan the user is using, or how can he or she change it? Might be some channels are missing. The list can go on, but there is no need for the user to worry about. As the user can always get the solution to the problem by contacting the Aol verizon Customer support number team.
Oct 23, 2019 | HIS Computers & Internet
NORTON Tech sUppoRt pHoNe [+1]-[8OO][8O3][1O69] nbmber us..vs.cs Usa NORTON USA phone number is ranked #2 out of 2 because 7,728 NORTON USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach t he NORTON USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, NORTON USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. NORTON USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact NORTON USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling NORTON USA Calling NORTON USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from NORTON USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with NORTON USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare NORTON USA's phone numbers against each other. Contacting NORTON USA in General While I8OO8O31O69 is NORTON USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach NORTON USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact NORTON USA.
Oct 23, 2019 | Norton Computers & Internet
See all Sony DDS SDT-9000 DAT Tape Drive Questions
Sony DDS SDT-9000 DAT Tape Drive Logo
238 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
