Looking for batteries for nikon n60 35 mm
SOURCE: Err message in N60
If your lens is set to F/22 or the smallest available on your lens, this is not a user problem. Take it to your local camera repair shop ( usually $100 to $125 repair to phase or sequence switch ).
SOURCE: Nikon N60 35mm camera error code FEE
Check your lens aperture ring setting. It must be set on the highest number I.E. f16,f22,f32..
SOURCE: My Nikon N60 35 mm camera shows the fEE message
Your lens is not set to the smallest aperture (highest number). Turn the camera off, rotate the aperture ring so the largest number is lined up with the mark on the top, push the aperture lock tab, and turn the camera back on. The aperture ring is the one closest to the camrea body with numbers like 4, 5.6, 8, 11 etc on it. The largest number will be 16, 22, or 32 for most lenses. If it still doesn't work, turn off, remove & replace the lens, and recheck the aperture ring setting.
SOURCE: I have a Nikon N60 35mm camera its displaying F3 3
It's not clear from your question that this is actually a problem as you haven't said what the display is doing to cause you problems actually using the camera.
What is certain is that it's supposed to display a F number in the viewfinder. Along the bottom of the display will be a number (shutter speed), an F number (aperture setting, when in auto or shutter priority modes this may not exactly match what's set on the lens), and moving bar + - scale too indicate over (+) or under (-) exposure.
If you really don't know what the F number is nor what it's for then you need to read both a good photography for beginners guide and also the camera manual. Explaining the relationship between shutter speeds, aperture settings and film speeds in any truly meaningful way here is beyond the limited scope of FixYa as whole books are devoted to the subject, but you only need a few pages and pictures from the available publications to get a good idea.
You can download a free user guide for your camera at the address below. It's for a Nikon F60, but it's identical to the your camera which was called the N60 in North America to distinguish it from unofficial imports.
http://www.devicemanuals.com/guide/Cameras/Nikon/Nikon-F60-N60-Instruction-Manual-TmpNMU5qUT.html
I hope that I've helped and if so ask only that you return the favour by rating my answer. If I haven't helped then please add a comment to explain more about your problem and I'll try to give further assistance. Please note that I'm in the UK and will be unavailable for most of Sunday so please allow for the time difference and scheduling whilst awaiting any further replies from me.
SOURCE: do the old AF lenses
Hi ericm675, Yes they will. What you run into is were one uses a auto focus lens on a newer digital such as a D40. Some of the new digital cameras do not have the drive gear to turn the autofocus on the lens. Those newer cameras use electronics. Look on your camera lens mount at 7:00 you will see the drive pin. Look on your old autofocus lens you should see a slot where that pin fits. Hope this helps you.
