I'm having trouble with my Honda Pressure washer. I connected up the hose, trigger and water hose. Turned on the pressure washer, then pulled the trigger and started it up. Within a few seconds, I had good pressure and used on the roof for about 1 1/2 hours. Then I got off the roof and shut down the motor, and did something (forgetting to shut off the water hose). This was for about 15 minutes. When I started it back up, I do not have any pressure in the pressure washer. It is just spraying very lightly. What have I done? Is it an easy fix?
Leaving the hose on shouldn't cause a problem so don't panic. It sounds like you could just have a dirty nozzle. Try sticking a pin or something in the end of the nozzle (machine not running) and giving it a clear out. also if it is a two peice gun, split it and tap the squirting part on something clean like a workbench to clear any debris that might have got in there.
My Troy-bilt pressure washer model 020296, I hook up the garden hose and squeeze the wand trigger and water comes out, but when I start the engine I don't get any water.
I have an excell 2500, 6.5hp pressure washer. It spray correctly for about 2 or 3 seconds then the water just trickles out. I've replaced the wand with a new one and it didn't fix the problem. Any suggestions?
pressure washer engine slows down low pressure with trigger puulled. New gun and hoses
pressure washer pules when trigger pulled
Turned key made clicking sound motor tried couple times but it seemed hard then just clicking
