Whirlpool GU2400XTP Built-in Dishwasher Logo
Christa Williams Posted on Oct 28, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Won't get off drain/cancel cycle
When I close the diswasher, everything seems normal. Then when I press a cycle (and it does NOT matter which setting) the machine seems to override the cycle and go straight to the cancel/drain cycle, and the clean green light is on during this time. I let it run its course, thinking maybe I didn't let it finish fully before opening last time. It finished, the clean light came on, so I opened the dishwasher, closed it, pressed normal, and it did it again. It has done this more than 12 times today, and I am afraid to try anything since it seems like more than a hardware problem. We have a new baby and I'm desperate to use it: handwashing everything takes more than an hour!
  • Christa Williams Oct 29, 2008
    Turns out, it was simpler than I ever could have imagined: someone, whoever had last used the dishwasher had pushed the lock button, and locked the machine into the drain cycle. All I had to do was to hold down the unlock button which fixed it. Feeling Silly! Thanks for your advice; I'm writing into the handbook for the machine.
  • Anonymous Feb 18, 2009
    same problem. thanks for the info about unlocking. it worked
Anonymous
Level 2:
Scholar:
  • Expert 112 Answers
  • Posted on Oct 28, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
112
Questions
0
Helped
45321
Points
283
It sounds to me like you may have a float switch that is registering water in the unit when you try to start it. If the unit "registers"that there is water in the sump before starting a new cycle, it will try to drain it before starting. The switch is located under the lower acess panel. Sometimes, you can bounce the float (depending on model) inside the unit a couple times and dislodge it. If not, you will have to pull the lower acess panel and check the switch out.
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 • Dishwashers
Model #DU1015XTXS2
With the dishwasher door closed and the unit in standby mode or with no cycle selected and all lights off, press - heated-dry, normal, heated-dry, normal buttons in that sequence. Then press cancel..... wait until 2 minute cycle is done. Open and close the door and make sure it is closed. Then run another cycle.
Motor keeps running. Water heats fine. Help
One of the reasons for motor not draining during normal cycle is the check valve is stuck. It is meant to return to normal during drain cycle but close during wash. I think the cancel is resetting it and letting water out.
See this discussion.
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/26-129-977852-/Bosch-Dishwasher-won-t-drain-SHE43RF2UC64
2helpful
Our dishwasher won't drain completely. I ran it through a regular cycle but it was left with water in the bottom.
Have you tried canceling the cycle? To cancel, turn the on/off switch to on, then press and hold for three seconds the two buttons labeled "Cancel Drain". Keep the door closed for the next minute so that the dishwasher can complete the cycle. During this time the pump will remove any water from the washer. Also you will notice that Bosch dishwashers always leave a little water in the system to keep the seals from drying out and going bad.
Hope this helps
Mistakenly started a cycle, now water is in bottom of tub, how can I drain it?
To clear the cycle open the door and press cancel, close the door and it will cancel.
Below is a link to the manual.
Link:
DISHWASHER was locked now unlocked but won't run. Goes to drain/Cancel when you push the Normal Cycles
Wondering how you unlocked the dishwasher. Normally you would have pressed Heat Dry for about 4 secs.
I don't this action would have caused the problem. For dishwasher to run you need the door lock switch to operate. If door is not closed it will go to Cancel.
Check item 12 in this diagram.
KUDS01FK diswasher will not start cycle. Completes diagnostic cycle properly (disconnected stuck pressure switch). If you enter a setting and press start, nothing happens. After a few seconds the lights...
Hello
first push and hold the cancel for 15 seconds and the if that dont reset the control push these buttons
normal wash ,, hi temp scub
if either of these resets the control the you will have to replace the control panel / thanks
My whirpool quiet wash plus will not completey drain
lets see here you want at least ten bucks to just help me w/ my diswasher problem but if gee i figured it out all by myself i get squat thanks but no thanks.
Aug 28, 2009 • Dishwashers
Quick Rinse light was flashing at end of cycle. Opened and closed door and pushed Start. Quick Rinse and Cancel/Drain light are now flashing and machine won't start. Turned off power supply (30 seconds) /...
Ok try this, open the door and then hit these buttons in the following combination. HI TEMP - DRY - HI TEMP - DRY...then close door and press cancel...then wait for the pump to shut down. you should be able to run a cycle after this...If this fails to fix the problem give me the make and model # of the dishwasher, this can normally be found just inside the door.
Jun 22, 2009 • Dishwashers
Maytag quiet series
My manual says: 1- Close door. 2- Select cycle. 3- Press delay. 4- Push Start/Cancel. (As soon as start/cancel is pressed, the flashing should stop and the delay time will begin).
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
