Replace keyboard
SOURCE: I need Full Kit (Bezel Hinges & Backcover)
These guys have your parts and ship pretty quick. Good luck.
SOURCE: MSI M670
Your best bet would be a local repair shop. No one "sells" these as aftermarket products. Try ebay
SOURCE: where can I get a replacement screen casing for an
Dear friend, please follow the link for online buy your MSI M670 Laptop screen.
Link click here.
Thanks & waiting for your reply.
SOURCE: How to replace hdd on
Laptop hard drives are usually behind one of the panels on the back of the laptop.
Older laptops would have two screws on the side that the drive pulls out of the side of the computer.
Newer laptops the hard drive is inside.
Remove the four screws on the drive caddy and the hard drive simply pulls out the caddy. Order a replacement and reverse the disassembly instructions.
SOURCE: How do I reset my MSI m670 to factory reset.
Hey John!
For computers, there are no "factory resets." You can re-install your Operating System(OS), which will reset EVERYTHING. Before attempting anything, remember to backup all important files! Your computer should have came with some CD's that contain your OS. What you will need to do is first, enter the BIOS(by pressing F2(or w/e it tells you) at the first screen you see when starting up the computer.) From there you must make the CD/DVD Drive your first boot device. So by going to the Boot Sequence/Order options, you can change it there. Then Save and Exit the BIOS and restart your computer with the OS CD in the tray. Then follow the instructions!
G
If
this answer helpful please vote me.
Good
luck.
Thanks
for using FixYa
