Question about Kenmore 24 in. 16032 Built-in Dishwasher
Foggy glassess big problem
I have been having problems with foggy glassess for months please help
  • cricketandbo Nov 12, 2008
    I have filled the dispenser completely, non has been dispensed and the glasses are not any better
  • 547 Answers
Jet dry
Posted on Feb 11, 2009
6ya staff
SOURCE:
Hi i have a sharp 70" lED aquos tv. But recently there is a big dark foggy spot on the center of the screen. Can you please tell me what you think the problem is? Thank you
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 11, 2014 | Sharp Aquos Televison & Video
My sony cybershot DSC-H10 camera has a foggy screen
is screen is foggy/image formation is foggy,chaque the lens unit
Mar 06, 2010 | Sony Cyber-shot DSC-H10/B Digital Camera
My tv picture seems foggy, what do I do. I pressed the flash focus, little help. The convergence button, didn't really see any issue with the crosses
U needed CRT coolant,U have a halo white screen too?Try this wbsite.Tv repair World.com check it out buy and replace the coolant or convergence kit,must know how do soldering to change convergence parts.Or if u have any colors lines mismatch at all than it the convergence.
Nov 06, 2009 | Sony KP-51WS500 51" Rear Projection...
Residue on glassess etc
changes r that gritty residue is detergant .water should b around 160 to desolve the deter.
Jul 03, 2009 | GE Nautilus 24" Built-in Dishwasher
Removal of headlight assembly
You cannot clean the insides. The are sealed if you attempt to remove them, which is a big job in itself, you run the risk of damaging the seal and allowing water and moisture to get inside which could lead to more problems. What I would recommend is to visit your local parts store, and pick up a bottle of Maguire's cleaner wax. Apply some of the wax directly on the headlamps and with a terry cloth or a microfiber cloth rub the wax in real good with a little bit of pressure. Allow the wax to cure and then polish it off with a dry part of the towel. Generally these headlamps oxidize and causes this foggy or cloudy appearance.
Apr 08, 2009 | 2004 Infiniti G35 Sport Coupe
Zenith pv5263bt 53
If this is a projection TV, first you should check you lamp. Is it good (clear) or bad (foggy). If foggy, you should replace it. If it is good (clear) reseat it back onto the ballast (it just might be loose). If you are still having this problem, you probably need to replace the ballast
Mar 25, 2008 | Televison & Video
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
Kenmore 24 in. 16032 Built-in Dishwasher Logo
Top Kenmore Dishwashers Experts
vince
Israel Pineiro Jr
David Patricia James
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
