Oddly enough a simple solution that seems to work about 50% of the time is hiding the toolbar in your windows browser where the only bar left is the URL bar (the bar that you type addresses into)
It seems to be a java error where even a single pixel is different from what the java is trying to load thus trying to fix the error it shakes until the page finishes loading.
If this doesnt work let me know and i will look into it further
One thing to understand is that this is a difficult problem to pin down and may end up requiring the control board to be replaced.
The UL or unbalanced load error is displayed when the control board senses an out of balanced load.
You don't indicate if the washer is actually out of balanced or not when the code appears but the description of banging and shaking would indicate it is out of balanced.
If the washer consistently bangs and shakes in spin then I's suggest you remove the spin basket and check under it for obstructions that might prevent the washer from spinning smoothly.
