Sony DSR-45 Mini DV VCR Logo
Posted on Oct 28, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony DSR error code C31:30 & C31:23
My Sony DSR 45 player first displayed a C31:30 error message, after following instructions in the manual for a C31:?? command and other suggestions found on line (whacking it), the message went from C31:30 to C31:23.
It still is not working, can anyone help me? All the suggestions I have read from C31:23 have been directed at the Sony Camcorder.
Thanks
  • cutefish Oct 28, 2008
    Welcomejee,
    Thanks for the explanation to the error codes. Is there a way to fix this problem without having to send the DVR to Sony for repairs?
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on Oct 28, 2008
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2955223
Points
33084
Error codes definitions are bit technical and as follows...
C:31:30 error code shows problem of No FG signal when starting capstan motor.
C:31:23 error code shows problem of No S reel signal to system control.
Above info were taken from service manual and picture of service manual can be seen below...
Need further info, let me know.
Sony DSR error code C31:30 & C31:23 - cb7de16.jpg
  • Anonymous Oct 28, 2008
    I would suggest Sony service center to repair this unit.
    What was their estimate repair, any idea.?
Sony DSR 45 error code C3130
Follow this:
1helpful
Error codes c 31 70 of sony dsr 45ap
U can do one thing check the switch at the front of DSR is in remote or not. If it is not then.Then press the reset switch is just below the the LCD. or Press eject button with pressing power supply .
Erro Code 02-674
my sony dsr 570 displays error 02674 how can i solve the problem
5helpful
3answers
Sony DSR 25, error code C3140. Any advise. Only comes up when tape is inserted.
FG fault when starting drum.
It’s very possible that you have a bad drum motor.
2helpful
2answers
My cam is a sony dsr-390
Error code 91-258 is described as follows..
91- Microcomputer and its periphery device error
2- THREADING
5- S side reel FG
8- Detected abnormal current
Your camera got mechanical problem with Supply Reel and failed to load tape.
Error message 91-1E5
error 91-1E5 is "communication error between system control and DIF microprocessor". look for a loose ribbon cable internally, although component failure is a possibility.
1helpful
2answers
2answers
DSR 11 MONITORING AUDIO ON SEPERATE PLAYBACK SCREEN
you are correct
you can display data codes only on this unit
the manual can be found here
http://www.sony.ca/dvcam/manuals/DSR-11.pdf
2answers
Error on SONY DSR 1500AP
<div style="text-align:center; width:150px; font-family:Verdana, Arial, Helvetica, sans-serif; border: 4px solid #336699;"><div style="padding-top:5px; padding-bottom:5px; padding-left:7px; padding-right:7px;"><div style="font-weight:bold; font-size:12px; margin-bottom:5px;"><a href="http://www.adoos.in/post/6702295/broadcast_equipment_repairdsr_pd_170p">broadcast equipment repair,dsr pd 170p</a></div>
<a href="http://www.adoos.in/post/6702295/broadcast_equipment_repairdsr_pd_170p"><img src='http://img.adoosimg.com/7e53d6f9d826f017583632c34e442dcd-1-2.jpg' border=0 width="100" title='broadcast equipment repair,dsr pd 170p' alt='broadcast equipment repair,dsr pd 170p' ></a> <div style="font-size:10px;">SUPERB BROADCAST EQUIPMENTS & MAINTENANCE...</div>
<div style="font-size:10px;" align="right"> <a href="http://www.adoos.in">classifieds</a></div>
<div style="font-size:10px;" align="right"> <a href="http://www.adoos.co.uk/house-to-share">house to share</a></div>
<div style="font-size:10px;" align="right"> <a href="http://www.adoos.fr/labrador-a-vendre">labrador a vendre</a></div>
<div id="control" style="display:none">aaquierplnew</div>
</div>
</div>
u can check the cables from dr board to mother board as its a communication error.
1helpful
3answers
DSR 25
C:31:23 on a DSR-25 indicates a supply reel problem, most likely caused by a defective cassette housing. Best repair solution is to send it to an authorized Sony repair center.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
