Sewing Machines Logo
Posted on Nov 17, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Brother Embroidery machine thread keeps breaking
No matter which embroidery thread I use, the design starts, the thread bunches up on the bottom of the fabric and the thread breaks. I have used three brands and thickness of fabric stay under each garment without any luck. What am I doing wrong?
I also need better instructions on how to download designs. Help!
R.A. Ellis
Level 3:
  • Sewing Machines Master 12,731 Answers
  • Posted on Nov 17, 2017
R.A. Ellis
Level 3:
Answers
12731
Questions
Helped
2613464
Points
59176
Breaking thread usually indicates a threading problem. However, there are a multiple of possibilities. On most domestic machines, the presser foot must be in the raised position when threading the top. Yet, you've obviously rethreaded so it's not likely an incorrect thread path. The tension setting could also be a problem or there's a problem with the bobbin or bobbin thread. Have you changed out the needle?
Why does the upper thread keep breaking Brother
Troubleshooting Embroidery Thread Breaks
Machine Embroidery What To Do When Your Thread Keeps Breaking Pt2 FSL...
Basic thread Break Fix
Bill Boyd
Level 3:
Top Expert:
  • Sewing Machines Master 53,816 Answers
Bill Boyd
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11925488
Points
172802
The needle thread tension is wrong
bunching up under the material indicates that it is too loose
1 Related Answer
Anonymous
  • 109 Answers
  • Posted on Aug 23, 2010
SOURCE: Brother Embroidery machine thread keeps breaking
It doesn't matter so much the thickness of the stabilizer but more a matter of it being taut like a drum and the proper stabilizer for the fabric you're using. Couple of reasons the thread breaks...the thread gets caught on the edge of the spool in the crack where the thread originally starts, you're not using the right size spool cap or the upper thread is wrapping around the spool pin. When I use my 170 for embroidering I always use the vertical spool pin to eliminate this problem. Try it and let me know how you make out.
My brother 4500D keeps giving me an error message check and rethread upper thread and the thread is bunching underneath my embroidery
If the display reads "Check and rethread upper thread", follow the steps below to resolve the issue:
1. Upper thread may be broken.
2. Upper thread may be caught on the spool on top of the machine.
3. Upper thread spool may have run out of thread.
4. Replace the needle in the machine with a new needle. Your needle could be bent or burred causing the thread to break.
Turn your machine off and rethread the machine from the start.
1helpful
I have a Brother Pacesetter PE - 100 machine where can I find or download a manual for this machine?
Search Results
    ETP027 - Brother International - Home Sewing Machine and ...
    www.brother-usa.com/.../accessorydetail.aspx?...ETP0...
    Brother IndustriesFind Dealer ... Download individual embroidery designs from Disney®, Nickelodeon and ... Fresh Green 100% Polyester Color Fast, High Shine Embroidery Thread ... BuyBrother Home Sewing & Embroidery Machines from Authorized Dealers ... PS3100,Pacesetter® PS3700, QC1000, SE270D, Super Ace I, ULT-2001C, ...
    Home Sewing Machines - Brother
    www.brother-usa.com/homesewing/software/
    Brother IndustriesIf the operating system of your computer is Windows Vista™, you can find support .... of design creation to owners of any Brother Pacesetter ULT model sewing machine. ... Click HERE to download "My Custom Design" Instruction Manual. ... If the software version of your PE-Design is Ver.1.x to Ver.5.x, an update program is ...
    Retired Products - Brother
    www.brother-usa.com/homesewing/.../retiredmodels.as...
    Brother IndustriesBrother - Your Home Sewing Machine and Innovis Embroidery Machine Choice. ...Find Dealer. >> go. Product Selector. Download individual embroidery designs from Disney®, Nickelodeon and more. Brother Sews ... View Details. Brother CS100T.CS100T View Details. Brother CS6000T ... Brother Pacesetter® PS3700.
    PE500 - Brother
I have a brother xl 5500 it keeps breaking the top thread no matter what i do
Go back to your instruction manual, some available online. to Re-thread the machine completely and make sure you are threading correctly. If that's not it, you may have thread jammed in a mechanism and it needs a technician's tools to get at it properly.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Cotton breaks on Brother Embroidery Galaxie 2100 machine
Try turning down your top tension setting a bit. If its at 4 or 5, i would turn it down to about 3 ish. Cotton thread is more brittle than polyester and rayon thread.
Hope that helps :)
Chris
Once I set up my design card and select design, the needle moves
Hi, and welcome to FixYa. If I understand your problem, the needle goes in and out of your fabric, and the embroidery hoop moves, but the machine does not actually start embroidering your design right away....did I get it right? If have time to answer a few questions, I can give more accurate instructions.
  1. How long have you had your machine?
  2. How long have you been doing machine embroidery?
  3. Do you have a manual for your machine?
  4. Look at the back side of your design - do you see lots of bobbin thread, or hardly any?
  5. Have you taken lessons for your machine or for embroidery?
  6. When your design is finished, can you where the machine skipped stitches?
Here a couple of things you can try (if you have already):
  • Make sure you use an embroidery needle, not a universal. In most cases, you should use a size 90. Change your needle after each project. A blunt need can cause your machine to skip embroidery stitches anywhere in the design.
  • Rewind or replace your bobbin. Make sure you use bobbin thread in your bobbin when you embroider - it is thinner and gives you better tension. If pre-wound embroidery bobbins are compatible with your machine, I recommend that you try one and compare the result with designs sewn using the bobbin thread you've been using.
  • Normally, you should loosen your tension a little bit when you embroider. When you look at the back side of your embroidery, you should see more bobbin thread than embroidery thread.
I owned an embroidery business for several years, and I have six different embroidery machines of my own - so with a little more info from you, I think I can help.
Pfaff creative half-speed and thread breaks
YIKES - what a nightmare! We can approach your problem two ways, but to determine whether the problem is your machine or your design, I need to know if you have been using one design, or if you've tried to embroidery several different designs and are getting threadbreaks about every 10,000 stitches, no matter what design, needle, thread, and bobbin you use.
Here are some rules you should following whenever you embroider on your machine:
  • Change your needle and insert a newly wound bobbin every time you start a new project
  • Use a size Embroidery Needle - size 90 for most projects
  • Check the backside of your design - you should see alot more bobbin thread than embroidery thread. If you don't see enough bobbin thread, loosen your top tension. If the tension is set automatically, change it manually.
  • Your design might be the problem. Some designs have WAY to many stitches. If you haven't already, choose several different designs with different styles - for example, a monogram, a design that is mostly satin stitches, a design that is mostly straight stitches, and so on. Sew one or all over and over so you determine whether your thread will continue to break about every 10,000 stitches.
I hope this helps. Machine embroidery is so much fun once you've learned and practiced. I hope to hear from you - machine embroidery is not hard to learn, but there is a lot to learn. Thanks.
If you want to get right to work, skip the troubleshooting and answer as many questions as you can or have time for. It is possible that your problem is the design and not the machine. Try one suggestion at time so you what helps and what doesn't. Questions first:
  1. Is the machine brand new, or new to you?
  2. Do you have your manual?
  3. Do you been embroidering by machine for a while, or are you just learning?
  4. Does this problem occur with every design you sew, or is it one particular design that you are having trouble with?
  5. How many total stitches are in the design you are trying ot sew?
  6. What kind of thread are you using (rayon, poly, sewing?)
  7. Did you buy the machine from a dealer, and if so, does it have a warranty?
  8. Have you taken lessons on how to use your machine for both sewing and embroidery?
  9. Are you familiar with embroidery backings, needles, and threads and how to choose which to use for a particular project?
1helpful
2answers
Tension on upper thread?
It sounds like the machine needs to be timed, seek out a sewing machine repair shop for this service.
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
