Cell Phones Logo
Posted on Feb 24, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
ZTE N762 Reset
Tried: In Safe and Normal Mode To get in the market or in the settings screen before the error occurs to do a factory reset. I have been trying for several hours. This solution is not working. Is there any way to perform a factory reset/formatting/hard reset/ whatever with the phone turned off (combination of buttons or whatever) because it doesn't seem I will be able to get to the settings menu... ever.
Anonymous
Level 3:
  • Master 380 Answers
  • Posted on Feb 24, 2012
Anonymous
Master
Level 3:
Answers
380
Questions
0
Helped
102708
Points
1118
Menu>Apps>Gallery>Themes>Scroll to Theme that you want to delete and press options>Delete
After that you select and hold the application which you wish to delete and..." Here is what you have to do in order to delete/remove/uninstall (call it whatever you want) themes from your Nokia C5-03: Menu - Settings - Application Mgr. - Installed applications - then you will see the installed app. in your phone, after that you SELECT and HOLD the application which you wish to delete and after you do that a Pop-Up wish appear written UNINSTALL in it, you then select Uninstall - YES and the application will be removed from your phone. Use the same way to delete songs too, just SELECT AND HOLD the song you wish to delete and the pop-up will appear, you then should click DELETE and job done ;) Hope i was clear on this explanation and wishing this will help you!
4helpful
5answers
Zte privacy protection password
i have the same problem, not fixed by hard reset or enter any number, its because the phone have an Android security password and its shows any time
2answers
I have tried all of the suggestions in the forum including a factory reset but my Toshiba Excite Tablet remains in safe mode. How do I remove the tablet back to normal mode?
Most likely it is dead. If you tried a real factory reset, then just look for another tablet. Toshiba is not going to help you as, from my experience, they do not care after they sell you the prodcut and it gets out of warranty.
Consider Samsung.
Zte n910 is locked need to hard reset for zte n910
Warning Hard Reset will erase everything on your Device !
You can reset your ZTE device's password: Turn off your phone, then turn it on. Select emergency dial. Input *983*987# in emergency dial-up pad. It will restore factory settings and your personal data will be erased.
1. From the Home screen, press the Menu Key and touch Settings.
2 Touch the Privacy
4 Touch Factory data reset.
5 Touch Reset phone.
6 Touch Erase everything.
How do i get the tv to full screen
Check the picture aspect ratio. If it is different to that of normal, this kind of fault can occur. Do a factory reset to this set. It will bring all the settings to its factory mode settings.
Unable to reset ZTE N762 phone
Hi,most smart phone has app's that comes with programs that protect your phone ,like your compurtor,It has to have a security I have a LG . One of my app's is a security app, call lookout and one section has a restoer,and backup, If you go to setting it might work, or juet pull da,/batt;and let it for a few.put, batt;/back in.
4helpful
3answers
ZTE Z990 when hard reset it says failure. package corrupt. How to fix?
The solution of your ZTE hard reset problem:
http://www.hard-reset.com/zte/
3helpful
How can I reset my ZTE N762 without using the phone. I got 5 times attempt for the password and got blocked. asking for my gmail account but i forgot the password. I cant use my phone at all.. Is anybody...
I Have a ZTE N762 and the phone always get stuck on the android logo when restarting it...it there a way to fix this problem without having to download a bunch of programs?
Mar 24, 2012 • Cell Phones
2answers
How to reset my ASPIRE 5534 Series laptop do to
I can't get my Acer Aspire 5534 to play movies on DVD
Top ZTE Cell Phones Experts
vince
nexrad_chris
Paul Carew
Are you a ZTE Cell Phone Expert? Answer questions, earn points and help others
