Question about Yamaha RX-V800 Receiver
Will only power-on after multiple atempts.
I have a Yamaha RX-V800 receiver now for a couple of years. Very good. It started with a problem of not powering itself on. Sometimes it will power-on but if you try to press any other button (s) it will shut itself down again and you have to try many times untill it powers-on again. Once succesfull, you have to let it work for quite some time to be able to start selecting the various functions on it. It has been to the shop many times but it always returns with the same problem. The nearest big town that might have a Yamaha authorized repair shop is at least 3000 miles away. What is the problem??? Thank you John Jezierski
  • 1 more comment
  • Anonymous Nov 07, 2007
    Reciever powers on and immediatly powers off
  • Tigerpaw Dec 27, 2007
    Have had this receiver for 5 yrs or so and now will not power on.
    In the past 6-8 hours it will power on and work for 10-30 minutes and then shut off.
    I checked the impedance switch and for loose speaker wires.
    I did add 2 new exterior speakers to the "B" speaker connection.
  • Anonymous Jun 11, 2008
    Would not power up after many attempts did one time and performed ok then later blinks one time and overloads drops out completely dead like there is a shorted semiconductor possible in the protection circuit.
    Sergeant:
  • 395 Answers
That problem is well known problem with a memory capacitor on the stand up board that is the control board. It is .47F 5.5 volt capacitor that resembles a button battery. The cap leaks all over this board the fluid is conductive and corrosive. So the cap must be removed and the board scrubed clean with contact cleaned and dried before replacing with new cap. the unit can run without this cap but if the power should be removed all customer settings will revert to the default. also check the copper ground screws for tieghtness.
Posted on Jul 08, 2007
    Novelist:
  • 236 Answers
John, i was with yamaha before and i experienced this kind of problem in some of their models including rxv800. this is grounding problem and modification has to be made. if Yamaha authorized center will not modify the grounding and just follow how it is then it will keep on coming back. i can not be specific though which boards needs grounding. it has to be well inspected and do the modifications. thourough check and observation needed.
Posted on Mar 31, 2008
Hello, I also had this problem with my RX-V800 and I sent it out to Tweeter and they found a memory cap that went bad. They replaced it for $14.00 along with a labor/service charge of $110.
Posted on Sep 25, 2006
    Scholar:
  • 72 Answers
Could be a broken or cold solder joint on the main board. I assume you have checked all speakers and wiring to look for shorts. Second it could possible be the protection circuit in the amplifier itself is malfunctioning. finally it could be a component on the circuit board that fails under load any of these conditions can cause an amplifier to go into protect mode. A good shop tech should be able to find the problem with the schematics. If you have had it in several times for the same problem you may want to try a different tech.
Posted on Sep 01, 2006
SOURCE:
Yamaha RX-V800 shuts down when any control button is pressed
What if you DON'T use the remote? Does it shut down when just using it?
If SO, you have a bigger problem.
If NOT, it sounds like the remote is hosed - sending a code to shut off.
Do you have another remote of any brand that you could set to do something simple, like change volume? Don't train it from the original, though, or it would do the same thing.
Feb 13, 2010 | Yamaha RX-V800 Receiver
Config Problems After Repair
Sounds like they centre has configured your speakers to "none". You need to hook it up to a tV or monitor and go through the menu to "speaker settings" and make sure you select either "sml" or "lrg" for the speaker type. Also ensure on the LFE settings that you select either "swoofr" or "both."
Nov 02, 2008 | Yamaha RX-V800 Receiver
Yamaha RX-V 800
give me more details of trouble... let me give you advise if it can be done. 800 does not have industry standard parts mostly by yamaha only or made to order by yamaha. I have the same unit before, i have the manual too.
i use to work with yamaha service saudi arabia 6 years
Feb 24, 2008 | Yamaha RX-V800 Receiver
Yamaha RX-V800 Composite Video Signal Problem
Hey there fontdude, I will begin assuming you are running your a/v cable into your receiver and then out to the TV or Monitor. If this is the case, I suggest you run the video cable direct from DVD or VCR device to Tv/monitor. You can still run the audio through your receiver. The nature of your problem was probably related to video signal strength being weakened as it ran through your receiver. Good Luck! Let me know how it works for you.
Feb 09, 2008 | Yamaha RX-V800 Receiver
Yamaha rx-v800 remote control's damaged
it can be accessed via the main unit controls but you need to go through your manuals. Maybe you can get your remote repaired still... maybe not badly damaged caused by corrosion.
redrivera0314@yahoo.com
Feb 04, 2008 | Yamaha RX-V800 Receiver
Yamaha RX-V800 - No audio on left and right channels
I too am experiencing this problem.... and my receiver is only 5 months old. Its a RX-V661
Oct 30, 2007 | Yamaha RX-V2500 Receiver
Problem in yamaha rx v800
Hello!!! Are you electronic technician? You should see the transistors Q22A, Q22C, Q19C e Q19A and its drivers on Main Board. All the best, Rasgador
Aug 03, 2007 | Yamaha RX-V800 Receiver
Rx-v800 shuts off after few seconds
Hi, You should try to see, on main board, the ground G2(TP00385), just to make sure if the screw is too tight. Its location on Schematic Diagram (Main) is E8. All the best, Rasgador
Oct 27, 2006 | Yamaha RX-V800 Receiver
Yamaha RX-V800 Receiver Logo
252 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
