Hi
I'm having Dell XPS m1330 and i currently running on wins vista ulti 32bit.
I've tried to install the extigy external soundblaster but it seems vista doesnt support. Is that any solution for my problem? Thanks!
The problem is.. creative site doesnt make this driver for vista user..
Any else solution?
Creative stopped supporting the extigy. No Vista drivers are available.
I have a same problem
SB Extigy won't even load the software on 64 bit Vista. I might be able to figure the driver issue out if it would just load the software. Anyone have a solution?
Same thing here but the Extigy software won't even load on 64 bit Vista. If I could get it to load I might be able to resolve the driver issue. Anyone got any ideas?
Same problem here but the software for Extigy won't even load on 64 bit Vista. If I could get it to load I might be able to resolve the driver issue. Anyone have any ideas?
92 Alpha fifth wheel water problem. When I hook up fresh water hose to fresh water intake the water is pouring out of bottom of fresh water holding tank. I turned the valve on pump with same results. How can I get fresh water to go to pipes directly instead of in tank? Could it be a broken pipe under there somewhere?
Thank you.
