SOURCE: Loud Buzzing Sound
since you changed the lamp my next thought is that the color wheel has failed,,,most good road techs can replace it in the home..the cost would be between 220.00 and 350,00 depending on the company...
SOURCE: buzzing noise
You need a new color wheel. Partstore.com is a good place to get them.
Check out:
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
SOURCE: cooling fan buzzing
Yes,don't do it yourself,and you need to have repair tech. asap,cause if the cooling fan is not working properly,that could trigger other parts in the tv to be malfunction.
Hurry,just it fix!
solutiondoct
SOURCE: hlp5067w won't come on & I've replaced the bulb.
If you hear a clicking sound in your bulb area like an arcing sound it's probably your ballast trying to fire up your bulb. new ballast easy to replace and around $100.
SOURCE: LOUD BUZZING NOISE WHEN WATCHING TV, WHEN I MUTE TV IT STOPS
try replacing av cords..if not replace tv
