Cable company had me unplug all my tv's everything is fine on all the tvs except the small 2004 naxa tv dvd combo unit i have in a dressing room. I have tried auto searc for cable tv several times and it is not picking up the channels. I AM NOT SURE ABOUT THE CABLE SETTINGS AND CANNOT GET IT TO RECOGNIZE THE CABLE CHANNELS.
SOURCE: I lost the remote for naxa 13 inch. Need codes for
Hello
I've with me over 368 type of universal remote control codes with me.It seems to be very difficult to get a universal remote code for your NAXA tv. Anyway I searched amoung them and go one and I send to you hearwith. Just try.
Remote control: Comcast Digital Transport Adapter Universal Remote.
Code found for Naxa [11998]
programming TVcontrol
The Comcast Digital Adapter remote control is pre-programmed at the factory to operate the Digital Adapter. The Comcast Digital Adapter remote also contains a universal TV library to allow you to control the Power and Volume of your TV.
1. Turn on the TV
NOTE: Please read steps 2 to 4 completely before proceeding. Highlight or write down the codes and device you wish to program before moving on to step 2.
2. Press and hold SETuntil the Red Light blinks twice, then release SET.
3. Locate the code for your device in Manufacturer's Codes on the back of this user guide. Brands are listed in alphabetical order with the most popular codes listed first.
4. Enter the first five-digit code for your TV. If you perform this procedure correctly, the Red Light will blink twice
NOTE: If you enter an invalid code, the red light will display one long blink and exit the programming mode. Repeat steps 2 to 5 with a valid code.
5. Aim the remote control at your TV and press Power once. The device should turn off. If it does not respond, repeat steps 2 to 4, trying each code listed for your brand until you find one that works. If it still does not work, try Searching For Your Code.
OK
SOURCE: My Naxa NX-546 LCD TV/DVD combo no longer has
Tries unplug,replug tv back about an hour later.The tv should be resetting itself back to factory setting,sound should work now.Still have the same problems.The tv Tuner signal board is shorted and the causes.That the board,where the incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
SOURCE: my naxa 19" flat screan
Hi, This could be an internal fuse in the tv itself, worth a check if you are confident yourself, make sure you replace it with the exact same type and rating, if it blows then there will be a pretty bad fault somewhere on one of the panels, most likely the power supply.
Please! if you are going to attempt anything yourself be careful, always unplug the TV first before attempting anything and be aware that power can still be held within the TV even when off.
If you are at all unsure please consult your local TV technician.
* With the remote control in hand, press the POWER key to
turn on the Presentation TV.
** Press MENU repeatedly until the Setup menu appears.
*** Using the Up/Down arrow on the remote control, highlight
Auto Program on the screen
**** Press the Right or Left arrow to go to the Auto Program
menu.
***** Using the Up/Down arrow, choose either Cable TV or Off-
Air Antenna on the screen.
****** Press the Right or Left arrow to begin the Channel Search.
******* Press ENTER when the channel search is done.
Note: Auto Program finds channels being received by the TV
tuner
Cable will not work unless you subscribe to a cable service
OK.
